Un-winterizing a Scamp - Page 2 - Fiberglass RV
Old 02-11-2011, 10:47 AM   #15
If the anti freeze was the RV non toxic type you do not need to take it anywhere/or do anything special to dispose of.
I do not normally drink the water out of my water tank but at least once a year and usually in the spring after I have flushed out the anti freeze I normally add no more than a 1/4 cup of bleach to a *full* tank of water and let it sit over night - then run all the taps for a couple of minutes. Then drain the water tank from the freash water tank and the holding tanks and fill the fresh water tank up again and run the taps again using the water pump. Then empty the tanks again - open the fresh water tank drain valve to speed up emptying the tank and dont forget the plug on the hot water tank as well to drain it. Fill the freash water tank again and it should not smell at all.
Others may have better suggestions but the above works for me. :-)
Old 02-13-2011, 10:09 PM   #16
Wallo's Avatar
Utah
Thanks to everyone for your suggestions. I ended up rinsing and adding water to my fresh water tank. It only hold 10 gallons. When I got to Quartzsite, I opened up the hot water heater and WHOOSH, 6 gallons were gone. Being my first time dry camping, I under estimated usage and ran out of water the 2nd day. I'll get a 7 gallon tank for my next dry camping outing. If it weren't for the fact that it still gets below freezing here some nights, I'd have rinsed and filled everything before leaving. It won't be a problem in the summer.
Thanks again everyone.
Alice
Wallo is offline   Reply With Quote
Winterizing Scamp in Pacific NW HappyScamper Care and Feeding of Molded Fiberglass Trailers 1 10-22-2010 12:00 PM
13' Scamp / Winterizing Question Sheryl M Care and Feeding of Molded Fiberglass Trailers 4 01-03-2008 08:43 PM
Winterizing Gerry Care and Feeding of Molded Fiberglass Trailers 27 10-11-2006 07:08 AM
Winterizing stevenff Problem Solving | Owners Helping Owners 7 11-29-2005 07:51 AM
Winterizing Legacy Posts Care and Feeding of Molded Fiberglass Trailers 10 09-20-2002 09:09 AM
