Uneven trailer braking - Page 2 - Fiberglass RV
Old 02-03-2007, 07:10 AM   #15
John & Sandy M's Avatar
Trailer: 1999 Scamp 16 ft
You haven't said whether or not you have inspected the brakes.
A leaking seal will put enough grease between the magnet and the drum to lower the braking action.
Also a little grease on the brake shoes themselves will cause a loss of braking on that wheel.
I inspected the brake shoes when I had the wheel bearings cleaned, inspected and repacked. The grease seals were replaced at the same time as they were damaged during removal. No grease on the shoes and there looked to be about 1/4" of lining depth left on the shoe. I wish I had thought about brake adjustment at the same time but it's been a long- long time since I've seen drum brakes that weren't self adjusting.
John & Sandy M is offline   Reply With Quote
Old 02-03-2007, 12:18 PM   #16
Brian B-P's Avatar
... I wish I had thought about brake adjustment at the same time but it's been a long- long time since I've seen drum brakes that weren't self adjusting.
Even with self-adjusters, I always manually adjust to something close when the drums are taken off, so they will be right without waiting for enough brake applications to take up the slack... but then with the cars I rarely take a drum off unless I'm putting in new shoes.
Braking controllers Matt in SV Towing, Hitching, Axles and Running Gear 2 06-04-2010 04:29 PM
Uneven tire wear on one side Bobbie Mayer Problem Solving | Owners Helping Owners 12 06-01-2010 05:28 AM
Uneven tire wear Tamid Towing, Hitching, Axles and Running Gear 6 03-29-2010 11:13 AM
TV Braking Issue Tamid Problem Solving | Owners Helping Owners 9 04-14-2009 05:11 PM
Braking, Transmission for towing Paul Kaplan Towing, Hitching, Axles and Running Gear 5 06-30-2008 06:14 PM
