Upper Bunk Weight Limit - Fiberglass RV
Old 10-31-2011, 11:04 AM   #1
Trailer: 1979 13' Boler
Does anyone know the weight limit for the upper bunk on a Boler?
Would it support an adult?
Thanks,
Noel & Grace
Red-Dwarf is offline   Reply With Quote
Old 10-31-2011, 11:35 AM   #2
WildBirder's Avatar
I've read in several places that it's 100 lb. Just hearsay but I thinks it's pretty accurate.
WildBirder is offline   Reply With Quote
Old 10-31-2011, 12:08 PM   #3
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
110 lb or less unless, you reenforce the attachments.
Old 10-31-2011, 01:08 PM   #4
Okay, now I've read/heard everything from 80 to 110 lbs. All I know is I don't want to be the one on the bottom if the top falls!
Old 10-31-2011, 03:16 PM   #5
Donna.
Old 10-31-2011, 05:46 PM   #6
Noel, if you absolutely need to have an adult sleep in the top bunk, consider adding cinch plates in all four corners on the bottom of the top bunk: Clinch Nut Plates - Rockler Woodworking Tools and straight table legs from bottom of top bunk to top of bottom bunk: Shop Waddell 35"L x 3-1/4"Dia. Pine Butcher Block Traditional Wood Table Leg at Lowes.com= You can get them alot cheaper locally I'm sure, but the weight would be completely off the fiberglass hinged area at the front which is the weak area.
The legs are then removable when you want to go back to gaucho mode.
Old 10-31-2011, 06:01 PM   #7
Pam Garlow's Avatar
Trailer: U-Haul 1985
I don't know of any adult that would want to sleep on that top bunk including me
Old 10-31-2011, 07:12 PM   #8
The top bunk has head room, it's the bottom bunk that's "cave like." By time a cushion/bedding is put down, there's about a foot between nose and that top bunk. I think it's really made for little kids or storage.
Old 10-31-2011, 07:51 PM   #9
Trailer: Fiber Stream
... or pets.
Old 10-31-2011, 10:11 PM   #10
We're trying to look at ways to not have to make up beds each night. We were thinking that we could sleep in the bunks and leave the main dining table up, but I think that's probably too problematic.
I think our better option would be to take out the top bunk and convert the bench seat into two smaller seats with a small dining table between them and not use the main dining table, leaving it as a bed.
Thanks for your thoughts...
Noel & Grace
Old 11-01-2011, 11:06 AM   #11
When my dog was still alive and I was traveling on my own I would used the upper bunk so I could keep the table up on my Scamp. I added an extra post a bit closer to center for more support which still gave the dog room to get into the bottom bunk. People who saw my set up use to laugh as the bottom bunk is bigger than the upper bunk but not big enough for a person and a large lab. Stopping him from joining me at 2 in the morning was not an option. :-)
Old 11-02-2011, 03:43 PM   #12
CindyL's Avatar
Illinois
There are posts of how people have beefed up their bunkbeds if you search.
CindyL
CindyL is offline   Reply With Quote
weight
Trillium 1300 Upper Bunk Bed Jeff Y. Classified Archives 0 10-05-2009 11:58 AM
Upper bunk in 76 TM14 Surfside Steve Smith Problem Solving | Owners Helping Owners 2 08-04-2008 03:06 PM
Upper Bunk Completed Christi V. Modifications, Alterations and Updates 3 02-21-2008 08:12 PM
replacing the upper bunk jojo93 Modifications, Alterations and Updates 3 07-02-2006 10:33 AM
Reolacing the upper bunk jojo93 Problem Solving | Owners Helping Owners 2 06-28-2006 09:12 PM
