Using trailer in freezing weather - Page 2 - Fiberglass RV
Old 12-15-2013, 09:07 AM   #15
cpaharley2008's Avatar
I'm not sure that is what did it, If I saw you wearing a lot of lipstick, I'd go the other way……..
Jim
Never in doubt, often wrong
Old 12-15-2013, 09:27 AM   #16
Trailer: Escape 5.0 TA
W. Mass
Haven't seen it mentioned but for winter use/storage I've been draining everything of water, run a gallon of antifreeze thru the pump and lines, then blow out the lines from the city water connection at low (30-40 psi) pressure. The antifreeze ends up in the traps and grey/black tanks and gets clears all water out of the lines.
I've got clear lines in my Starcraft as opposed to the red and blue I seem to recall in pictures of Escapes builds. After the first 4 or 5 years of leaving the pink in the lines thru the winter I found the lines took on a pink color s I started doing the above. I just go dry come cold weather, using the CG's bathrooms and a 5 gallon jug for consumption.
padlin00 is offline   Reply With Quote
Old 12-15-2013, 03:35 PM   #17
Cyndi B.'s Avatar
Trailer: 2010 Scamp 5th Wheel/2007 Toyota Tundra/2015 Tundra
Montana
WE use to put the pink stuff in our garage toilet. I don't know if that was the constant swimming or the pink stuff that got the two mice.
Cyndi B. is offline   Reply With Quote
Old 12-15-2013, 10:22 PM   #18
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
It may be worth noting that RV or "pink" antifreeze's active ingredient is propylene glycol-( link) not the more toxic ethylene glycol used in car antifreeze, which is responsible for many pet poisonings each year.( link)
Black and grays freezing? Cathi General Chat 16 12-19-2012 06:03 PM
Looking for Full Time Trailer for Cold Weather prone2wander Hi, I am.... 1 04-16-2012 06:17 PM
Camping In Freezing Weather Patrick M. Problem Solving | Owners Helping Owners 13 11-27-2007 05:33 PM
Pulling a fiberglass trailer in temps below freezing Buck62 Problem Solving | Owners Helping Owners 6 12-06-2006 08:19 AM
Battery freezing Legacy Posts Care and Feeding of Molded Fiberglass Trailers 12 06-26-2003 10:20 PM
