Using Zep to restore oxidized fiberglass - Page 2 - Fiberglass RV
Old 07-01-2013, 04:58 AM   #15
Originally Posted by gihuff View Post
I put on a coat with a buffer, then about 20 minutes later another coat.
Shines no doubt, but looks a little nasty. is it the buffer or just need most coats? Also should i buff with a clean terry cloth buff pad after the last coat?
You don't need a buffer and two coats isn't enough.
Old 07-01-2013, 06:41 AM   #16
Zep............
Will a person have the task of stripping this stuff off in a couple years?
gihuff is offline   Reply With Quote
Old 07-01-2013, 07:16 AM   #17
KevinPete's Avatar
Trailer: 1995 Scamp 13
Don't need a buffer, just wipe it on. Shine won't really come out until the 3rd or 4th coat. Then it will amaze you. I've been toying with the idea of a coat of wax over the Zep, but it's really not needed. With some of the changes I've been making in the Scamp, I'll probably end up stripping it and recoating the whole trailer next year, just to keep it all even.
KevinPete is offline   Reply With Quote
Old 07-01-2013, 07:17 AM   #18
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
If you use the zep stripper , my experience is that it is easier to strip than putting on the 5 coats of floor wax. I stripped the polyGlo after 3 years . Had issues with ammonia , I think the zep stripper was about $9/gal and well worth it only took about 45 min. To completely remove everything but the roof which I had spent about half a day on with the ammonia.
Michael J.
mmeyer is offline   Reply With Quote
Old 07-01-2013, 07:42 AM   #19
Don't use the buffer. Just a plain lint free cloth. The buffer seems to throw it around and not aply evenly. With a cloth you just wring it out and wipe and when finihed you can start again with next coat , dries quickly. I notice a big difference after the 3 rd coat and then put on two more, GREAT SHINE>
RRJR is offline   Reply With Quote
Old 07-02-2013, 11:09 AM   #20
Trailer: Thor
Buffer VS. micro fiber
I think that the use of the buffer to apply the floor finish might be a bit much as the product dries rather quickly and the spatter that the buffer would produce maybe detrimental to your project, micro fiber towels worked real well for me, applies evenly and with 4-5 coats you should have a good glosy finish.
JSR54 is offline   Reply With Quote
Old 07-02-2013, 11:13 AM   #21
Trailer: Thor
wax over
I have been toying with the idea of applying a carnuba wax over my zep finish also, mainly to help to repell any black streaking. Let me know how it works out for you.
Old 07-02-2013, 02:49 PM   #22
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
Wax dosen't keep the streaks off, maybe a little easier to clean though
Old 07-02-2013, 03:26 PM   #23
I found after the Zep is on all you need to do to remove any marks is wash with cold water the Zep forms a pretty hard finish.
Old 07-07-2013, 09:29 AM   #24
Zep.............
I have the issue of just part of this camper I bought,is chalky. (2004 Scamp 5th)having been stored under a carport, the top is factory flawless in shine as well as the passenger side and rear but the front and driver side was exposed to the sun and elements. I feel unwilling to put zep over these shiny sides but zep came out great on the nose! I am trying to find a way to merge the two?
Old 07-08-2013, 11:35 AM   #25
Trailer: 77 Scamp 13
I have the issue of just part of this camper I bought,is chalky. ..... I feel unwilling to put zep over these shiny sides but zep came out great on the nose! I am trying to find a way to merge the two?
You might try a paste wax over the top but I don't really see how the zep would "hurt" the unweathered sides of the camper. 4 to 5 coats over the whole thing and I would think it would all just look shiny. Assuming you used something such a Barkeepers or fiberglass oxide remover to clean off and the chalky weathered surface.
My 35 year old scamp has some sections that are very weathered, some much less weathered. Redmaxx (different brand of zep product) blends them fine by the 4th coat.
Someone mentioned waiting for a sunny day to take a picture of the shine. Overcast but fairly bright day works better for that type of picture. Indirect light through clouds shows the shine without the reflections and glare of direct sunlight.
Old 08-06-2013, 09:24 PM   #26
Myron Leski's Avatar
Trailer: 19' Escape
NM
Six coats of Zep applied three years ago. Six more coats applied 3 weeks ago. Did nothing in between but wash it down with Mr Clean and a hose.
Myron Leski is offline   Reply With Quote
Old 08-17-2013, 03:44 PM   #27
Pam Garlow's Avatar
Trailer: U-Haul 1985
Does anyone have a photo of the Zep container? There seems to be several types around
Old 08-17-2013, 06:32 PM   #28
Trailer: 19' Escape
NM
Here you go....
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
Restore boler 78 Yvon Chayer Modifications, Alterations and Updates 36 04-22-2012 09:28 PM
78 Scamp restore XL milkjug Modifications, Alterations and Updates 7 01-31-2012 09:45 PM
1980 Scamp Restore Lawrence W Modifications, Alterations and Updates 1 05-12-2010 09:57 AM
restore or modify? Rands E. Problem Solving | Owners Helping Owners 5 03-30-2008 11:16 AM
Restore Feature Mike-B General Chat 24 12-14-2005 10:18 PM
