Venting with solar power vents - Fiberglass RV
Old 06-12-2014, 01:49 PM   #1
GregLS's Avatar
Trailer: 17 ft Burro
Lightbulb Venting with solar power vents
I've been looking for soalr vent fans to help keep air moving through the 17' Burro to cut down on the dreaded mold mildew and moisture. My searching led me to this video and web site
Solar Vent Cover & Fan for RVs and Trailers
It's a bit pricey but it does make for a simple and effective install.
I'll prolly look into building something similar on the cheap.
I'm in no way affiliated, just want to pass along a stumble upon.
Here's another option if i can figure out a good way to install it. I like that it has a on/off switch
Cordless Solar Powered Greenhouse Vent Wireless Reversible Fan w Battery Back Up | eBay
GregLS is offline   Reply With Quote
Old 06-12-2014, 01:53 PM   #2
I installed solar vents on the bathroom (2) PVC vents that go through the roof and on the Fridig Vent.
Old 06-12-2014, 04:01 PM   #3
Trailer: 17b Escape
$400.00 for a fan??? An entire solar panel system is about the same price.
J Mac is offline   Reply With Quote
Old 06-12-2014, 05:14 PM   #4
Trailer: 13' Scamp
cheap solution
Just install a 12 V socket on the solar panel side of the controller with a switch. Then insert an automotive USB charger into the socket. Then cut apart a USB cable and insert into usb port of charger. Then wire a 5 V muffin fan with less then 1 A current draw The controller would disconnect the fan once the sun went down, so no worries about running down your battery.
A little bit convoluted I know. This issue is that once the battery is fully charged, the "12V" solar panel voltage will head up to its open circuit voltage of 18-20 V which would tend to incinerate a 12 V computer fan. I suppose you could just assume the battery is full (good assumption for storage application) then use a resistor to bring the voltage down to a safe operating point for the fan. The resistor would need to be able to handle about 1/3 the power of the fan. When the battery was charging, the fan would mostly turn off, which isn't bad thing. The problem is that the fan would only run during full sunlight. With a little guess and check on the resistor value, you could probably get it to work OK. Now of course you have a resistor burning enough power to be a bit of a hazard in a constrained space.
I just leave the windows open on the camper since I have the window covers that won't let rain in.
Maxxair 00-455000 Window/Maxx Louvered Vent by Maxxair
KevinScamps is offline   Reply With Quote
Old 06-12-2014, 07:10 PM   #5
Trailer: 2014 Escape 21
Virginia
What do you think of this, currently out of stock but due in soon.
Heartland America: Solar Auto Vent
Old 06-13-2014, 04:15 PM   #6
Trailer: 17b Escape
Why would someone opt for the $250.00 (new price) solar blaster fan when the entire trailer can be solar powered for about the same $ ?
Old 06-13-2014, 08:24 PM   #7
tartosuc's Avatar
Trailer: 2007 uhaul ct13
Quebec
You really dont need much power to have a fan working. In your egg.
In my uhaul, the original solar panel is connnected directly to the 4 computer fans i have installed in roof vent. I have a second panel charging the battery.
During the day the fans turn all day without using battery power. At night they stop turning when the sun comes down...if i need the fans, a switch get them connected to the battery.
What i like about this setup is that when it cool enough to not use the roof fans at night, i can leave the switch to solar and the fans start turning slowly as the sun comes up...keep the camper cooler a bit longer in the morning.
tartosuc is offline   Reply With Quote
Old 06-14-2014, 06:17 AM   #8
GregLS's Avatar
Thumbs up
Great idea! I'm working on a similar build for by egg.
Old 06-14-2014, 07:22 AM   #9
Timber Wolf's Avatar
North Florida
Very interesting. What is that the fans are connected to? A piece of Lexan or such? Also, how is it attached to the vent hatch?
Old 06-15-2014, 07:23 PM   #10
tartosuc's Avatar
Quebec
Simple piece of mdf wood.i used two metal srew to attach it by the center to the metal bar that is going across the vent. The one holds the vent handle.
Old 06-16-2014, 02:40 PM   #11
GregLS's Avatar
I bought this solar panel
Coleman 6-Watt 12-Volt Solar Battery Maintainer-58022 at The Home Depot
and scavenged a 12 volt dc fan from an old computer. I used clear plexiglass from HD. I marked the hols from the removable screen in my vent. I cut the holes in the plexi with my Rotozip on the lowest RMP so as not to melt the plastic.
While my Burro is parked, I've just got the solar panel laying on the roof and snakes the wire in the vent. I'm working on ideas for a more permanent install of the panel.
Here's the pic.
Old 06-17-2014, 09:48 AM   #12
Trailer: Aliner folding & Weekend Warrior toy hauler
Ohio
Maybe a vent cover like the MaxxAir and let convection take care of the circulation.
Keep in mind that air can't go out the top unless it can come in somewhere else.
Shopping for a fiberglass TT
Currently own;
2009 Pontiac Vibe pulling a 2009 Aliner Sport = 22 MPG
1998 Ford E150 pulling a 2006 Weekend Warrior toy hauler = 8 MPG
beemerphile1 is offline   Reply With Quote
solar, solar power
Don't mind me, I'm just venting... Frederick L. Simson Modifications, Alterations and Updates 10 10-05-2009 05:19 PM
alternative venting Refridgerator Coach George Jessup Problem Solving | Owners Helping Owners 6 10-05-2008 10:03 PM
Improving fridge venting Roy in TO Modifications, Alterations and Updates 0 07-16-2008 06:45 AM
Just VENTING! Deb in MN Modifications, Alterations and Updates 7 06-03-2006 07:31 PM
