Vents and Vent Options - Fiberglass RV
Old 01-23-2009, 10:11 PM   #1
Trailer: Coleman
Would someone give me a quick rundown on the vent and fan options?
Turbo MaxxFan
Fan Tastic Fan
Plain hatch
Others?
Solar options
I am looking for something of known quality. I'll pay extra to avoid junk.
Solar preferred unless it's junk. 12 volt preferred over just vent hole.
I'd just like to buy the right fan and not have problems later. Mostly for cooling during hot Texas evenings. Opening is 9.25x9.25
Many thanks
Tom
Tom B. is offline   Reply With Quote
Old 01-24-2009, 12:58 AM   #2
Roy in TO's Avatar
Others?
Endless Breeze 12V quiet, powerful and flexible in use.<a href="http://www.fantasticvent.com/products/endless_breeze/endless_breeze.html" target="_blank">
</a>
Old 01-24-2009, 06:17 AM   #3
james kent's Avatar
Trailer: Boler 1984
Are you talking about a pop-up?
You'd need some type of flexable wiring for an electric fan.
Old 01-24-2009, 12:58 PM   #4
Raya's Avatar
Just a note on size: I have a ~9" x 9" vent in my Boler (the original Hehr vents in the Trilliums were also this size), and I started a thread about a month ago to see if there were any options for replacing that size except for the slightly cheesy looking Elixir ~9" vent. Beween my own searching and the ansers in th ethread, it seems that this is the only vent still made (RV type) in this size. (There are some marine hatches that are ~9" x 9" but they are a slighlly different animal - although they could be used.)
The point I'm winding up to is that you will most likely be enlarging the opening in your trailer and going for a 14" (or other sized) vent.
On the solar topic, there are marine vents that have solar fans, but they are usually max of ~ 4" x 4". They don't lift open or let light in, but just sit and whir to pass air in or out (your choice). Look for a "nicro solar vent" if you want to check one out.
Coming from a marine background, I was a bit surprised by the apparent flimsiness of all the vents, but then they are much cheaper (and often lighter) than the marine offerings. I did find one that looked to be of better quality - can't remember right now where it was, but it was a replacement vent for a Westfalia VW van. (maybe samba.com?)
Raya
Old 01-27-2009, 05:17 PM   #5
Trailer: 84 16 ft Scamp
We installed a MaxFan in our Scamp. It fit the original opening. It was quite expensive, but a quiet deluxe unit with a multi-speed, reversible motor and thermostat.
Were I to do it again, I would leave the original vent installed and mounted a Wal-Mart 12 volt fan that can be found in their camping departments. The cost would be 80 to 90 percent less.
We travel with our cat. She likes traveling and presides over the Scamp, rarely showing any desire to get out. In warm weather we crack a window and leave the fan running on low speed to maintain a reasonable temperature in the Scamp for her.
Old 01-27-2009, 07:54 PM   #6
Raya's Avatar
That's what I've decided to do when I replace my vent: Replace vent with just a passive flap, and then have a separate fan. Sometimes I like a breeze blowing right on me; sometimes not. And sometimes I'd like the maximum air flow with no fan at all (and no fan blades in the opening).
I'll probably enlarge the opening to 14" x 14" although I haven't decided that for sure yet. As it turns out my current skylight only leaks when there is a torrential downpour, and then it's just right through a crack in the lid (i.e. it's not drizzling in through the mounting flange and going behind the Ensolite or anything like that). So for now I've taped the crack and will replace the vent in spring.
Raya
Old 01-29-2009, 10:27 PM   #7
Lance MacArthur's Avatar
Trailer: Boler 13 ft 1972
When we went through the fan decision while remodeling our Boler, we decided on a Fantastic fan. It required widening the vent hole, making it a complex project. After cutting the hole, we made a hardwood gusset with sides to match the curvature of the roof. Then fiberlassed the whole unit onto the roof. This allowed a perfectly flat surface to mount the fan, which comes with a thermostat, is reversible, and has 4 speeds. It runs on 12volts.
After three years of use, it works as good as new. I seldom use the air conditioner we put in, as the fan is adequate to cool sufficiently. The reversible is good for sucking out cooking odors and heat from the stove when cooking inside.
A long tale to give fantastic fan a big thumbs up.
Lance MacArthur is offline   Reply With Quote
Old 01-29-2009, 11:57 PM   #8
Raya's Avatar
Lance,
I had wondered about the curvature of the roof if enlarging to 14" x 14". For my current ~9" x 9" the opening is small enough that not much of a curve develops. On boats, we usually have to build a wooden (or fiberglass) base in order to mount the flat hatches on the curved decks (although some boats have factory-molded flanges that do that).
Since I hadn't heard much about that on campers, I wondered if the typical plastic vents were flexible enough to conform to the curved shape I suppose it depends some on which camper and where you mount the vent. It's something I'll have to check out in more detail prior to doing the job (unless I put in a new ~9" x 9" vent).
Raya
Old 01-30-2009, 10:28 AM   #9
james kent's Avatar
Trailer: Boler 1984
I removed the original 9X9 metal roof vent. It had been damaged by the "previous owner" and was in pretty poor shape. I had no difficulty cutting a larger hole and attaching a 14X14 acrylic vent. The centre of the roof section on the Boler doesn't have a lot of curvature. At least not enough to make a difference. A good layer of butyl tape and we've had no problems with it in ten or twelve years.
Old 01-31-2009, 05:16 AM   #10
And, butyl doesn't have to be the same thickness all the way around. Two layers in one spot, three in another still seals very well.
Old 01-31-2009, 01:18 PM   #11
Raya's Avatar
Good to know - thanks!
This is what I was figuring, but it's sure nice to have confirmation beforehand. I suspect it's a combination of the roof not having that much curvature, plus it's being a bit flexible (in the grand scheme of things; not that it's super flexy).
Thanks.
Raya
Old 01-31-2009, 03:16 PM   #12
Trailer: 1970 Boler
I have the fantastic fan in my Boler. The plastic frame of them tends to flex to the curviture of the roof anyway. Works great blowing out air. Close all the windows except the door window and the breeze inside is incredible. IF you do a search on here, I posted my temperature results and the termperature dropped quiite a few degrees. USed ones go for less than half on Ebay.
Kurt in BC is offline   Reply With Quote
Fantastic Vent and Camco Vent Cover d_wildemann Care and Feeding of Molded Fiberglass Trailers 0 06-19-2009 05:30 AM
roof vent options john flynn Problem Solving | Owners Helping Owners 9 06-03-2009 11:17 AM
Covering Vents? Gerry Problem Solving | Owners Helping Owners 2 10-25-2006 11:59 AM
A/C vs. Fantastic Vents.. Legacy Posts General Chat 6 06-12-2003 02:55 PM
Leaky Vents Legacy Posts Problem Solving | Owners Helping Owners 9 04-12-2003 12:13 PM
