Vertical Seam Versus Horizontal Seam - Fiberglass RV
Old 03-15-2015, 09:09 AM   #1
Trailer: In the Market
Kansas
I am seriously considering the EggCamper but have not had much luck researching the vertical joining of the two halves. I know there are some older units, Burro and U-Haul, that have that seam. I am familiar with the horizontal one since that is most prevalent in the posts.
I am wondering sort of the dynamics of joining and the wear and tear on that joint. I am thinking that you are walking on that seam. I was reading something about flex and how anything joined together will have flex points were joined which makes perfect sense and the molded fiberglass having less seams would have less possibilities for the joints to fail and leak.
Any thoughts or experience? Thank you.
Cathy P. is offline   Reply With Quote
Old 03-15-2015, 09:26 AM   #2
I have seen a few Burros with ceiling water damage from seam leakage, but they were usually in otherwise really unmaintained shape anyway. Can't say I have ever seen a belly band leaker, but several have been mentioned.
BTW: "I am thinking that you are walking on that seam" Unless you are walking on the roof I don't see that as a problem.
Old 03-15-2015, 09:54 AM   #3
cpaharley2008's Avatar
The seam in an Eggcamper is sealed with a piece of "U" shaped moulding the covers the seam. No leaks as long as the moulding is present. Some older horizontal bands over time leak and the rivets or screws underneath start to rust. That is why some are removed and then fiberglassed over the seam. The Eggcamper, relatively newer has not reached the 20-30 year mark where the seam needs attention.
Jim
Never in doubt, often wrong
Old 03-15-2015, 12:27 PM   #4
Tom Trostel's Avatar
Trailer: 1980 Bigfoot 17 ft
The vertical seam on my 42 year old Compact Jr does not leak.
Old 03-15-2015, 12:35 PM   #5
What vertical seam? I thought the Compacts (and kissin' cousins) all had a belly band-type seam...
Old 03-15-2015, 02:25 PM   #6
I don't think the Compact II has a vertical seam, but the Compact Jr is made from a right and left half. The seam is covered with tape and mine is beginning to flake off. In the linked photo look above the spare tire and front window.
Mission Tejas State Park, TX Photo by tomNjo | Photobucket
And this one has tape that has been replaced with reflective tape.
Mellow Yellow In Crescent City, CA Photo by tomNjo | Photobucket
The horizontal band around the middle of the trailer is simply decoration and is not there in the rear.
Old 03-15-2015, 02:42 PM   #7
Kansas
Thanks everyone! The Compact Jr., who would have thought since to me, I would have thought it had 4 pieces, quarters. Lovely photos and great looking unit.
I got to thinking about the EggCamper and since it has the wood floor, I think, above the fiberglass seam, that would distribute the weight across the area plus you have a double shell. And, I don't see myself on the roof walking around. I'm afraid of heights!
Old 03-16-2015, 08:53 AM   #8
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
Tom
Thanks for those pics. I hadn't seen one of those before. Neat looking. I'd love to szee it in person.
Walt
Old 03-16-2015, 09:37 AM   #9
Raz
Raz's Avatar
Vermont
Burro and others may have chosen the vertical seam because it would be difficult if not impossible to remove their shell from a mold with a horizontal seam. For example the protruding tail light mount would be an issue. Raz
Old 03-16-2015, 09:54 AM   #10
Trailer: Bigfoot B-17 CB
The vertical seam on the roof , the recessed side windows and the protruding rear window on the Burro all add structural strength without adding much weight. These are some features I really like.
Old 03-16-2015, 10:15 AM   #11
kirkman's Avatar
Trailer: 2007 Eggcamper & Homemade Tear Drop
I have a 2007 egg that has been dragged all over the north east by the PO and now by me to some cool boondocks where the roads are not the greatest. So far no sign of a leek any where.
Jason
If you think you are to small to make a difference just try sleeping with a mosquito - The Dally Lama
kirkman is offline   Reply With Quote
Old 03-16-2015, 01:51 PM   #12
Trailer: 77 Scamp 13
The belly band be it vertical or horizontal is cosmetic not functional. It just hides the ragged edges of the molded halves.
I seem to recall EggCamper uses adhesive as part of their joining process, not sure if they also fiberglass the two halves of the outer skin from the inside. Scamp joins the two halves with fiberglass so one would expect it to be nearly as strong as the shell.
One advantage the vertical might have is water has to flow "up" to get to the edges of the joined halves. Horizontal (Scamp at least) are set up so water flows behind the band and right over the sealed joint. If the joint seal leaks the band will insure water gets to the leak. The horizontal seams rarely do leak but if they do the trim won't help them shed water away from the leak. The way I would think a vertical band might.
Old 03-16-2015, 04:12 PM   #13
Sid
Sid's Avatar
Trailer: Parkliner 2014 V6 Jeep Cherokee
Roger
One thing I thought Casita, Scamp, and Parkliner shared was the overlapping of the horizontal seam (at least I didn't think it was unique to PL). You can see the 4" overlap in this photo I borrowed from Thom's previous post.
Sid
Don't quit your daydream.
Sid is offline   Reply With Quote
Old 03-16-2015, 07:05 PM   #14
Or both halves bonded together like Escape before the trailer comes out of the mold.
Use of Captain Tolley's on Horizontal Surfaces CampyTime Care and Feeding of Molded Fiberglass Trailers 20 01-08-2014 07:46 PM
List 13 foot eggs with a vertical seam (Burro type) Matt, H General Chat 0 10-07-2009 10:06 AM
Wanted: 30# Horizontal propane tank Lisa H. Classified Archives 3 07-17-2009 12:00 AM
Compact juniors: tape: vertical belly band Kent I Problem Solving | Owners Helping Owners 12 11-25-2008 12:05 AM
SOLD ~ Horizontal propane tank for sale jeanne Classified Archives 1 04-19-2008 11:13 PM
