want to reseal all of our windows - Fiberglass RV
Old 03-07-2016, 06:48 AM   #1
TheWanderers's Avatar
Trailer: 1988 Bigfoot Fiver
Kentucky
Is there anything special about the screws holding the window casing in the Scamp wall? Obviously size is important here, but I would like to replace the old screws with new ones that have clean heads and can be properly torqued.
"Not all those who wander are lost." J.R.R. Tolkien
TheWanderers is online now   Reply With Quote
Old 03-07-2016, 07:13 AM   #2
Trailer: 2014 Escape 21
Virginia
If you are resealing your windows you can get black butyl tape. Usually it is not on display but in RV parts stores but they usually have it in the back room. Besides being black it is wider to fit your window flange. I usually just paint the screw heads and reuse, if needed I get screws from the local hardware store. If you find screws that have stripped out the screw slot just move to either side and drill a new hole in the mounting ring only. Once you get the mounting ring off you will see how the ring mounts to the window.
Eddie
Eddie Longest is online now   Reply With Quote
Old 03-07-2016, 07:35 AM   #3
Kentucky
My reason for resealing is that almost every one leaks. During this process we will be able to completely clean out all of the drain holes as well as the frames. The screws are old, probably original from 1991, with pan heads with square holes that strip out easily so I'd like to replace with something that will torque down more readily to enable a better seal between the window frame and ring. We have found the butyl tape and are ready to work through one window at a time. My plan is to pull one screw and take it to Lowe's to find the replacements if no one has any specific recommendations regarding requirements.
We're also looking for a screen or a source to buy a replacement for one of the dinette windows; any recommendations for screens?
Old 03-07-2016, 07:52 AM   #4
None
Have you checked with your local hardware store, one that cuts glass?
Here in my small town Hardware they will make screens for many windows, they have several styles of frame material to fabricate the frame from, probably have something that will work in your window.
LyleB is offline   Reply With Quote
Old 03-07-2016, 08:46 AM   #5
trilliumdon's Avatar
Trailer: 1975 BIOD Extase
If you're going that far I strongly suggest you change the wood that holds the screws. I pulled the framing wood from my 13 trillium when it leaked and it was saturated with water. If you have the windows out there's no better time.
trilliumdon is offline   Reply With Quote
Old 03-07-2016, 09:23 AM   #6
tractors1's Avatar
Trailer: Escape 21 - Felicity
The square drive Robertson #2 drive IS the most common higher torque fastener screw on the market except for the star-drive head. You must not have the correct bit size; I routinely fasten square drive 4-8 inch long #10 and #12 screws in construction.
Almost every trailer I've seen in the last few years uses them.
Charlie Y
Old 03-07-2016, 09:25 AM   #7
Does Scamp use wood around the window frames?
Old 03-07-2016, 12:12 PM   #8
kdhanso's Avatar
Right Jon. No wood on Scamp window frames.
I resealed mine with butyl a couple years ago. I removed and cleaned off the old dried up foam seals before placing the butyl on the window edge. Reused my original Phillips head screws as there was nothing wrong with them. They were removed and reinstalled with careful use of my cordless impact driver. I didn't have any screws strip out. It's nice to have a helper on hand outside holding the window while you drive the first couple screws back in place.
Ken
Ken
kdhanso is offline   Reply With Quote
Old 03-07-2016, 02:47 PM   #9
Trailer: R-Vision Trail Lite
Since I seem to see a window leak/seal topic just about every month on this board I must ask "do all the fiberglass travel trailers have window problems or is this problem limited to certain brand or brands ?"
Uplander is offline   Reply With Quote
Old 03-07-2016, 03:05 PM   #10
I think the reason you see so many posts on window leaks in fiberglass trailers is that they last long enough to develop leaks in those areas.
The stick-build begin to fall apart, leaving the dealership.
Old 03-07-2016, 03:33 PM   #11
kdhanso's Avatar
Yep. I resealed my windows when I noticed the first leak which is when my trailer was around 16 years old. Most factory seals were still ok but I decided to redo them all at once.
Ken
Ken
Old 03-08-2016, 04:58 AM   #12
CampyTime's Avatar
Trailer: Scamp 13' Standard
Reading this thread with great interest. All of you smart guys know how to take a window out, where butyl goes etc. If I ever need to do so on my scamp 13, does anybody know of a step by step tutorial with pics that can help me with both words and visuals? I see a screw in ring around my windows. Other than popping out those screws, no idea what happens next.
Again, many posts on this forum are written by much more handy people than I. I usually have to learn by trial mistake trial mistake.
Cheers!
Wendy
Old 03-08-2016, 07:55 AM   #13
Wendy, try searching "reseal RV window" on YouTube. I found several that were very helpful. For me, I have to see it happen. If a picture is worth a thousand words, then a video is worth ten thousand!
Old 03-08-2016, 08:19 AM   #14
Glenn, I am sure your trailer is the best on this planet. Mine must be second best...it is a "sticky"... It is 16 years young...to is still like new...it has followed us (and the previous owner) around the country for many miles over roads both good and bad....no leaks...no major system failures.
My policy in life is "Never say never" and take every product and individual at face value...no two are the same...both stick built trailers and fiberglass trailers have problems unique to their type...none are perfect.
I came to this and several other boards in search of knowledge.
This board is a good source. There are many knowledgeable folks willing to help.
I learn something new every day. Thanks to all for sharing.
I have yet another question that I will put in another post today. It is a general knowledge question about that magic electric converter system all trailer have.
Happy Camping
windows
Windows, windows, windows Matt4483 Problem Solving | Owners Helping Owners 24 02-10-2016 12:50 PM
How often Reseal? melissab Care and Feeding of Molded Fiberglass Trailers 8 02-14-2012 02:09 PM
Trillium(2010) Window Reseal Raz Problem Solving | Owners Helping Owners 17 11-30-2011 11:36 AM
Reseal skylight on 2003 17 Bigfoot garylake Care and Feeding of Molded Fiberglass Trailers 5 06-28-2011 09:27 AM
Reseal or Full Re-seat Roof Vent? Trill 4500 Fred G. Problem Solving | Owners Helping Owners 6 09-06-2006 09:10 PM
