Water Heater Boler 1700 - Fiberglass RV
Old 08-07-2011, 01:02 PM   #1
Trailer: Bigfoot 2500 truck camper
Just purchased a 1978 Boler1700 and found this website to be a fantastic resource. Spent a weekend out boondocking nearby to find out what worked. The water heater leaked water constantly through a female drain hose fitting. No matter how I set the bypass valves it keeps pouring through. Tried unsuccessfully to plug it with a male hose plug and hose washer. Not sure why the heater has no drain valve or plug just an open drain. I read quite a few threads here on water heaters but mine a suburban 6 gallon does not seem to match what I saw. Anyone familiar with this? I will try to get a pic to show where the water is coming from.
Rene is offline   Reply With Quote
Old 08-07-2011, 02:03 PM   #2
IllAnnoy
It is not entirely clear to what you refer, but if you mean the hot water tank drain... It should be pipe thread, not hose thread.
Please pardon me if I misunderstood.
Old 08-07-2011, 02:13 PM   #3
No problem Floyd...that is what I do not understand. It is a hose thread fitting and I do not understand why it is there or what the previous owner did to it. Working on some pics.
Old 08-07-2011, 02:36 PM   #4
Pics
Here are a few pics.
The hose fitting with a hose washer that I inserted. The plug would not seat deeply enough to seat the washer.
Unless I can figure out a good reason to leave the hose fitting in, I would like to take it out and put a drain valve in.
Old 08-07-2011, 04:07 PM   #5
IllAnnoy
Is that hose thing an adapter which is pipe thread on the other end?
If so, then a large Easyout might just do the trick along withe a little penetrating oil and maybe a heatgun?
UPDATE!... READ BRIAN'S NOTE BEFORE DOING ANYTHING ELSE TO IT that little flange on the inside of a normal hose fitting can be snugged up with a rounded screwdriver handle and a couple of taps then try two gaskets.
Also... spray battery terminal cleaner should clean it up pretty quick!
Old 08-07-2011, 05:48 PM   #6
Thanks Floyd. There is pipe thread on the back of the hose fitting. Getting a tool on it is a real challenge though. I think I need a better wrench. I am going to spray it with super lube and see if I can get it to shut off like a tap.
Old 08-07-2011, 08:28 PM   #7
now it is closed
Finally got it to turn counterclockwise and backed it all the way OUT and lo and behold it stopped leaking from the drain anyways. Now there is a constant drip from the pressure relief valve. I flushed some water through the valve and I am hoping the valve seal might swell a bit and stop dripping but MAY have to replace it? Thanks so much for your help this far Brian and Floyd.
Old 08-08-2011, 07:16 AM   #8
kevin61's Avatar
Trailer: Two 13 ft Bolers and one 17 ft Boler
Sounds like a familiar experience. I did the same thing while trying to figure out my water heater. I went through the same process, thinking what idiot designed this stupid thing. You should be able to turn that whole female fitting in a clockwise direction and it should stop your water draining. Check out my video. At 4 minute 40 seconds I am draining my tank.
Subscribe to my YouTube channel as I am in the process of a Frame Off restoration on a 17 ft. Boler. Taking my time, with a completion date of next summer. Once I work the glitches out of my new editing software I will get caught up on my videos.
http://www.youtube.com/user/kevinhenry61?feature=mhee
kevin61 is offline   Reply With Quote
Old 08-08-2011, 07:37 AM   #9
In the manual for my hot water tank it says that you may have lost your air cushion in the top of your tank.
Try draining and refilling the tank.
Bill K
Old 08-08-2011, 01:46 PM   #10
Thanks for the nicely rounding out this thread Bill and Kevin. The water has stopped leaking from the pressure relief valve. Everything seems to be working properly now. I enjoyed your video clips Kevin. I am moving towards LED lighting and I have 150 watts of solar panels to install. Picking up some good tips.
boler
Water tank for boler 1700? Patton M. Problem Solving | Owners Helping Owners 3 09-08-2009 03:15 PM
Coleman Hot Water Heater outside a Boler kevin61 Problem Solving | Owners Helping Owners 0 07-13-2008 06:11 PM
Hot Water Heater - Rusty Water terryw Problem Solving | Owners Helping Owners 9 07-15-2006 08:33 PM
