Water line issue - Fiberglass RV
Old 05-14-2013, 12:06 AM   #1
Trailer: Boler 73
Yukon
Water line issue
This has been written about, I'm sure. But for some reason the site isn't allowing me to filter the threads.
My Boler has one of those hand pump faucets, only the water doesn't make it past a certain level and then trickles slowly back into the holding tank. We're without water. Is the issue with the pump or the line?... I'm a total novice here. If it's an issue with the line, where does the hose go when it goes down. (I mean, is it a huge job? Does it require getting down and underneath, taking the holding tank out? I kind of just want to go camping. It was long winter.)
Thanks for the tips or the filtered leads.
jwykes is offline   Reply With Quote
Old 05-14-2013, 06:38 AM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
For future reference, by far the best way to search here is to use the Google box at the bottom of the search pull down. See illustration below.
It could be that the pump check valves are bad or that you have an air leak in the hose between the tank and the pump. If the hose and connections look good and the filter is not blocked, I'd probably pop for a new hand pump. These have been recommended.
Valterra RP800 Chrome Rocket Hand Pump : Amazon.com : Automotive
If you have the Leisure Products pump you can get a rebuild kit
Leisure Components 199-9 Repair Kit for Hand Pumps : Amazon.com : Automotive
Pex water line question Ron in BC Modifications, Alterations and Updates 15 03-12-2013 11:43 PM
Scamp 13' water line routing? JohnF Modifications, Alterations and Updates 4 10-20-2011 09:00 PM
water pump issue? biw314 Problem Solving | Owners Helping Owners 8 07-16-2011 02:32 PM
need help with 17 foot boler water line Marlean K Plumbing | Systems and Fixtures 5 06-11-2007 12:08 PM
