Old 09-28-2011, 10:07 PM   #1
RLP
Trailer: 72 Boler
Wave heater
Was looking for a heater for my 13 foot Boler and came across the Camco Olympian Catalytic Wave heater. Runs on propane and does not require venting (fresh air recommended). Also no fan so no elec. demand.
Do any of you folks have experience with this model? Good, bad, otherwise? Thanks.
RLP is offline   Reply With Quote
Old 09-29-2011, 09:07 AM   #2
Trailer: Casita 17'SD
I have one in my 17' Casita and am quite happy with it. You might find it difficult to permenently mount it with the clearance requirements. 12" above. 4" on sides. 30" in front & 6" below. Zero inches behind
LK Gray is offline   Reply With Quote
Old 09-29-2011, 12:53 PM   #3
Trailer: 2008 13 ft Scamp
Got the smallest size (Wave 3) for our Scamp 13 and it works great! Best thing is not having to hear a blower kick on and off all night. Plus the fact that it doesn't require any electricity. I mounted it under the closet door.
Jeff Peterson is offline   Reply With Quote
Old 09-29-2011, 03:55 PM   #4
Trailer: 1980 Burro
This has been discussed here several times, it would be worth a search to see what has been said in the past.
This link will get you started...
Vented cat heater
Andy B is offline   Reply With Quote
Old 09-29-2011, 04:12 PM   #5
RLP
Trailer: 72 Boler
Mounting it under the closet door is exactly where I planned. Your closet door doesn't get to hot??
What do you do for fresh air requirements? I have a 3/4 inch gap at the bottom of my ill-fiting door and I could open the roof vent an inch or so. I can't help think about the non-venting requirements of a propane device. I mean, there is still a nasty byproduct of combustion. Last thing I want is to wake up dead!!
Are there any Canadian suppliers for this heater?
Thanks for the replies.
Old 09-29-2011, 05:19 PM   #6
No, the closet door doesn't get hot. Most of the heat is radiated straight out into the living space. We crack the small window over the stove and a ceiling vent. So far we've only needed the "low" setting to stay comfortable.
Old 09-29-2011, 05:47 PM   #7
Joe Z's Avatar
Trailer: 1994 Casita Spirit Deluxe 16 ft
I have the wave 6 and it's too much..... the wave 3 in my opinion is a better choice like Jeff has.
Joe
Old 09-30-2011, 01:52 AM   #8
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: 1990 13ft. Scamp Custom (L-Shaped kitchen counter top).
I have used a Colman Black Cat heater (3000btu) that you screw a small cylinder to, and have found it to be to warm for me in our 13 foot scamp. These catalyst style heaters do put out quite a bit of moisture into the trailer, so be prepared for some water accumulation. I have been thinking of removing my furnace to gain more storage space, and mounting the Coleman in the existing opening and using an adapter to run the propane from the tongue mounted tank.
Wave 3 Cat Heater Not Available in Canada Michelle A Care and Feeding of Molded Fiberglass Trailers 4 03-31-2010 11:45 PM
installing propane line for Wave 3 heater April Wilcox Problem Solving -- Owners Helping Owners 27 12-22-2008 07:36 PM
Wave 3 Heater Installation Parker Buckley Problem Solving -- Owners Helping Owners 5 12-14-2008 07:28 PM
Have Olympian Wave Catalytic Heater User Guide rudock1 Forum Admin, News & Announcements 1 10-22-2008 04:37 PM
Wave 3 Heater install Gina D. Modifications, Alterations and Updates 14 06-04-2006 01:41 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
