weight rating - tires - Fiberglass RV
Old 02-24-2013, 09:20 AM   #1
What is the meaning of a weight rating for a tire. If a tire is rated for 1000lbs, does that mean
1000 lbs per axle?
1000 per tire (or 2000 lbs on an axle with one tire each side)?
1000 lbs total for the entire trailer?
The same rating could mean very different things.
Derek
glamourpets is offline   Reply With Quote
Old 02-24-2013, 09:38 AM   #2
Carol H's Avatar
Derek the load rating is per tire.
Old 02-24-2013, 03:20 PM   #3
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Since you don't specify trailers I presume the question is about tires generally, so I'd add to Carol's answer that in dual- wheel applications tires' load carrying limits are downrated, see examples on chart here
Note: "Dual wheel" means double pairs on a single axle.
Francesca
Old 02-24-2013, 05:44 PM   #4
Brian B-P's Avatar
Originally Posted by Francesca Knowles View Post
... in dual-axle applications tires' load carrying limits are downrated...
Note: "Dual axle" means double pairs on a single axle.
Correct - but it's "dual wheel", not "dual axle". A pickup truck with dual rear wheels is usually identified as "DRW" in manufacturers spec sheets, and is informally called a "dually".
When specifications include a load index (not a load range), tires intended for dual applications have both the load index for single use and the load index for dual use shown, separated by a slash. For example, 112/110 would mean 112 in single use, and 110 in dual use.
Of course, I've never seen a moulded fiberglass travel trailer with duals.
Old 02-24-2013, 05:56 PM   #5
Thanks- fixed! Started out as "dually"...
As I think I indicated, the O.P. didn't specify that the question was limited to trailers, so I thought the downrating of duals was worth mentioning.
Francesca
Old 02-25-2013, 06:05 AM   #6
Steve L.'s Avatar
1000 pounds per tire, as noted and up to 2000 per axle. I say that because weight on a trailer axle is rarely evenly distributed side to side and you can't use all of the axle's 2000 pounds if it means one side is over 1000.
tires, weight
Storage - Take Weight off Tires? Thomas G. Care and Feeding of Molded Fiberglass Trailers 9 10-02-2012 07:11 AM
Bunk Bed Weight Rating Trillium 4500 Donna H Problem Solving | Owners Helping Owners 1 09-01-2009 05:35 AM
Let some air out when weight off tires? David & Terry Towing, Hitching, Axles and Running Gear 1 01-08-2009 03:50 PM
Converter amp rating David & Terry Problem Solving | Owners Helping Owners 16 11-07-2007 05:03 AM
Your Vehicle Tow Rating. Chester Taje General Chat 34 12-29-2006 05:00 PM
