well maintenance - Fiberglass RV
Old 03-02-2016, 11:03 AM   #1
Trailer: Sidekick 1500 2014
Quebec
well maintenance
I bought my trailer New in 2014. Since then I drove moreless 5 000 miles. Should I cheked wheeels and brakes?
Balou is offline   Reply With Quote
Old 03-02-2016, 11:43 AM   #2
How often to service bearings is discussed fairly often here, and opinions vary widely. I used to do it every year, but decided that was probably overkill, since I only tow about 2-3000 miles a year. So now I am on a 2-year schedule.
Old 03-02-2016, 12:06 PM   #3
Quebec
Thank you! I will go to the rv médic.
Old 03-02-2016, 01:17 PM   #4
I bought a new Scamp in 2010. It has nearly 10K miles and I've never pulled a wheel. I was gonna grease through the "E-Z lube" but when I pulled off the rubber cap, the grease that was at the cup on both wheels looked brand new. I placed the caps back over the hubs and kept on trucking.
My wheel's arent "loose" (checking from top to bottom for 'play'), they spin freely and do NOT heat up on the road. I have adjusted the brakes once. I do not full-time and am not on the road continuously. I do occasionally pull 500-1000 miles round-trips. When not in use, I do keep my trailer under a carport and on jacks and spin the wheels as I walk by periodically year-round. I travel "light" on the trailer so there's a huge safety margin on my tires/axle from the factory specs....that DOES make a huge difference on wear-n-tear.
In my opinion, what Dexter recommends > pull the wheels and inspect bearings once a year regardless of the miles- to me is a JOKE! I feel the "average" user stands a MUCH better chance of contaminating the bearings/grease and/or over-tightening the wheels doing this every year. If I'm totally wrong, time will prove it out. 6 yrs/10K Miles and counting.
Old 03-02-2016, 07:07 PM   #5
If you have 5000 miles on your trailer from new you should have had one simple adjustment to the brakes by now.Initial wear is usually greater to as the brake break-in. Remember your trailer brakes are not self adjusting.
Old 03-02-2016, 08:53 PM   #6
sokhapkin's Avatar
SW Florida
Check wheel hubs temperature at the end of a travel day. If the bearings are not hot, they are fine. I'm not an usual "camper", I'm a traveler. I never stay 2 days in a row at the same place and I do few hundreds miles a day. Approx 20K miles/year. Once a year I do check/adjust the bearings tolerance, it's very simple task. Just jack up a wheel and check the motion with hands. Repack the bearings or ez-lube yearly.
Sergey
Old 03-03-2016, 02:25 PM   #7
C&G in FL's Avatar
Trailer: 2015 Escape 5.0TA
If you are recommending E-Z Lube as a means of servicing the bearings annually, you really should research how they work. If you do, you would probably change your last sentence to "Repack the bearings yearly."
What a long strange trip it’s been!
Old 03-03-2016, 02:36 PM   #8
It is quite clear how they work . I repack the bearings by hand only when I service the brakes,the rest of the time I repack them yearly using EZ-Lube.
EZ-Lube either works or it doesn't, empirical evidence says it does.
I take it that you think EZ-Lube is useless?
Emergency Maintenance - 6-18-03 Legacy Posts General Chat 4 06-18-2003 11:40 AM
AC Maintenance Question Legacy Posts Problem Solving | Owners Helping Owners 24 11-17-2002 06:15 PM
Bearing Maintenance Legacy Posts Care and Feeding of Molded Fiberglass Trailers 7 11-12-2002 06:08 AM
Oil change, tire rotation, other maintenance General Chat 0 01-01-1970 12:00 AM
