What a torsion axle should not look like - Fiberglass RV
Old 05-03-2010, 08:48 PM   #1
John and Jaci's Avatar
Trailer: 1972 Boler American ('The USS NeverSail')
We have replaced the axle on our 1972 Boler. The original axle was locked in the up position about 10 to 15 degrees up. After we replaced the axle John cut the old one in two so we could see just how bad the axle looked on the inside. Its quite impressive what 38 yrs of wear and tear looks like. Thought that others would be interested in seeing what it looks like.
John and Jaci | Our furry friends Chief and Scampy
1972 Boler American - The USS NeverSail | 2012 Jeep Wrangler Unlimited
John and Jaci is offline   Reply With Quote
Old 05-03-2010, 08:52 PM   #2
Mike Bromley's Avatar
Trailer: 1973 Boler 1300 (Glass-Fab
I'm about to find out. My hard-riding '73 Boler axle is being exchanged as I write.
Mike Bromley is offline   Reply With Quote
Old 05-04-2010, 02:52 PM   #3
Roy in TO's Avatar
Thank you,
That picture should become a "sticky" for everyone to see why they should replace their axle when it looks OK from the outside.
Old 05-04-2010, 06:51 PM   #4
Raya's Avatar
Just curious: What would a cross section of a good axle look like?
Raya
PS: I don't doubt this one was shot; just don't know how a good/new cross section would look as I have never seen one cut open.
Old 05-04-2010, 07:52 PM   #5
I would imagine that the rubbers would be in the corners of the outer tube, with the inner tube at 45 degrees to the outer tube, nestled in the nice bouncy rubbers, and not all filled with rusty grundge.
Old 05-04-2010, 08:03 PM   #6
Mike and Sarah K's Avatar
Trailer: 1979 Trillium 13 ft
New Brunswick
Raya
typically the center tube is at 45 degrees to the outer tube and the rubber on each corner would have been symetrical. The way I have been told to tell if it is burnt out is to measure the angle of offset of the inner tube from the outer tube. I don't know how far they can move before they are too far gone but the picture of the cut one above you can tell they are probably gone.
Mike and Sarah K is offline   Reply With Quote
Old 05-05-2010, 08:08 AM   #7
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
This is what mine looked like also before I replaced it.
Arm should be pointing down NOT up.
Old 05-05-2010, 12:41 PM   #8
Roger C H's Avatar
Talking
Attachment 27878
Hmmm. Maybe if you removed your anvil collection from the trailer...
Old 05-05-2010, 06:09 PM   #9
Highway68's Avatar
Trailer: '71 Boler 13 ft
Thanks for those pics, that is just what I have been wondering, I'm preparing to replace axles on two trailers, nice to see the inner workings!
Highway68 is offline   Reply With Quote
Old 05-05-2010, 08:22 PM   #10
Michel, Bouchard's Avatar
Trailer: Boler 1300 1973
Quebec
Attachment 27878
It looks exactly like before mine was replace 2 days ago, even the arms did hit the floor a couple of times (from what I can see, before I bought it). My Boler looked like a low-rider, now it's ready to go camping on some rough roads to go fishing.
You can see how my Boler was low before and how it is after, I also provided the link to where I had it done in that post:
Boler axle replacement
Boler 1300 1973
Jeep Wrangler 2dr 2012
Michel, Bouchard is offline   Reply With Quote
Old 05-05-2010, 08:45 PM   #11
Roy in TO's Avatar
Cut away views can be seen on the torflex documentaion here:
http://i.b5z.net/i/u/1080235/f/Torfl...ation_4-04.pdf
The square axle and tube are at 45 degrees to each other and the 4 peices of rubber are round fitting nicely into the triangular spaces between them.
Maybe someone here knows how to copy a picture from the PDF to post it.
Old 05-06-2010, 12:46 AM   #12
Yup!
Old 05-06-2010, 10:21 PM   #13
Roy in TO's Avatar
Way to go Mike!
Does that help you Raya?
Old 05-06-2010, 10:26 PM   #14
Raya's Avatar
Yes, thank you!
So it looks like the rubber "bands" should be more round and the inner square should be at 45 to the outer tube, as you-all mentioned. Thanks!
Raya
axle
Torsion arm angle Roy Kleiner Towing, Hitching, Axles and Running Gear 3 03-08-2010 09:25 PM
Trailer Axle 3500lb Torsion Kevin K Classified Archives 0 08-08-2009 06:53 AM
axle is an automotive axle on my casita tracy.c Towing, Hitching, Axles and Running Gear 26 07-30-2007 04:50 PM
Torsion Axle Lifespan David Schroeder Towing, Hitching, Axles and Running Gear 14 01-25-2007 04:25 PM
torsion axle lifetime? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 17 07-10-2003 07:46 PM
