What is the better surface for storing a fiberglass RV outside? - Page 2 - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Care and Feeding of Molded Fiberglass Trailers
Click Here to Login
Old 10-09-2016, 10:14 PM   #21
Wood contains water. Concrete contains water. When you tow the trailer, you drive on wet asphalt. Relax. Fergetaboutit.
After almost eight years, I finally replaced my Marathons that came with the trailer. Tread was in great condition. No rot.
I replaced them because the interweb says I should, and I don't want a flat. Had no issues at all.
Old 10-10-2016, 10:58 AM   #22
The reason for putting wood or rubber mat under the tires is so the dirt or concrete doesn't suck the moisture out of the tires. The wet is fine.
Old 10-10-2016, 11:29 AM   #23
Sorry. I don't buy that either.
What are you going to do about humidity in the air, or lack thereof?
Old 10-10-2016, 02:13 PM   #24
member
Isle of Wight
Don't tell the folks that live in Phoenix......
And how does a rubber mat make any difference to a rubber tire?
WizWid is offline   Reply With Quote
Old 10-10-2016, 02:51 PM   #25
Here's what tire manufacturers say:
http://www.goodyearrvtires.com/tire-storage.aspx
http://us.coopertire.com/Tire-Safety...ing-Tires.aspx
Old 10-10-2016, 03:35 PM   #26
I didn't make this up. I have read and heard about it from tire manufacturers and RV people for years. Dry dirt and unsealed concrete pulls moisture out of tires where they make contact with the ground and continues to dry out rubber. The humidity really has nothing to do with it. It's the chemicals so to speak in the dirt and concrete.
Old 10-10-2016, 03:49 PM   #27
Drive through a mall and count how many vehicles are parked with their tires on wood planks.
After more than seven years parked in my driveway on asphalt, my tires still looked new. If they do dry out, it must take decades.
Old 10-10-2016, 03:58 PM   #28
According to the links I posted, raising the tires off the ground is the ticket.
I found the pressure recommendations interesting. If you store off the ground, you should reduce the pressure to 10psi, but if they stay on the ground with weight on them, you should increase the pressure by 10 psi (subject to the limits of tire and rim, of course).
There is, of course, the obvious: protection from sunlight and high temperatures (as might occur on black asphalt). Oxygen, apparently, is bad, too, but not much you can do about that unless you remove the wheels and store in a garage or shed. Didn't know there was such a thing as a tire storage bag…
Seems to me how far you go with this depends on how long the trailer will sit. Some people (like me) use the trailer off and on all year long. I really don't want too much of a rigamarole to bug out, and if tire life is reduced somewhat, I accept that. On the other hand, if it was going to sit in storage for 6 months, I might remove the wheels, reduce the pressure, and store them indoors in bags.
spiderweb like cracks on fiberglass surface jondsw Care and Feeding of Molded Fiberglass Trailers 8 01-23-2023 10:35 AM
Storing Toilet Paper Roll in Toilet-Shower Combo S Sato Plumbing | Systems and Fixtures 24 04-18-2015 12:46 PM
Pantry organization- how are you storing your food? Bobbie Mayer Problem Solving | Owners Helping Owners 15 04-30-2008 03:38 PM
It just gets Better and Better james kent General Chat 5 11-26-2006 01:48 PM
Storing security Quint General Chat 4 01-16-2006 10:27 PM
