What is the better surface for storing a fiberglass RV outside? - Fiberglass RV
Old 09-27-2016, 06:14 AM   #1
Trailer: Scamp 13 Std.
I am wondering what is the best surface for storing my Scamp outside when not in use in order to minimize the effects of moisture on the RV frame.
I have already been advised that grass is not good at all, in terms of moisture problems, and that concrete and asphalt are not much better, both being said to wick up moisture from the ground under a stored vehicle. It seems to come down to some kind of gravel or crushed concrete.
I'm interested in opinions on this from those with experience with similar moisture problems.
Thank you!
Bill MN is offline   Reply With Quote
Old 09-27-2016, 06:35 AM   #2
Trailer: 2005 Scamp 16
The place where we store our camper (a commercial RV storage lot) uses finely crushed rock for the pads. I hadn't really thought about that before so I'm interested in the responses that you get.
emij is offline   Reply With Quote
Old 09-27-2016, 06:47 AM   #3
Raz
Raz's Avatar
Vermont
Mine sits on mostly packed dirt. Has for 6 years. A proper gravel pad is in the works. One of these days. . I had a little surface rust so I painted the frame this year. In my opinion air circulation is the best way to keep moisture damage from happening. I suppose if you are really worried about it you could park your trailer on a tarp? Raz
Old 09-27-2016, 07:01 AM   #4
Trailer: 2015 Scamp 13D
Being on a limited budget, I got 4'x4' treated 3/4 inch ground contact plywood sheets and put those down. They keep the trailer from sinking in the mud or creating ruts when the ground is wet. They also create a clean place to walk around the trailer. This is much less expensive than bringing in rock or paving.
Rich G. and Val F. is offline   Reply With Quote
Old 09-27-2016, 11:37 AM   #5
Alabama
Outside storage
I have a 17 casita and a 29 airstream. My she'd has a gravel floor in addition I place plastic down and put a treated 2x12 on the plastic level it and park trailer on them the plastic keeps the moisture back and the wood levels gives firm surface.
J Mitch is offline   Reply With Quote
Old 09-27-2016, 11:49 AM   #6
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
Some use a pair of inexpensive jack stands, on the trailer frame, to lift the trailer off its tires. I would think any packed surface would suffice for jack stands.
Harbor Fright, ~$25 a pair, 3 ton, steel, 12+ pounds
~$40 a pair, 3 ton aluminum, 4+ pounds
Might need a cinderblock under each rear stabilizer for them to reach the ground.
Personally, mine has been on concrete since 2003. Some years I even put the tire covers on, but less than a third of the time. From my perspective, you're overthinking this but it doesn't hurt to do a sanity check every now and then.
Quando omni flunkus, moritati
Old 09-27-2016, 01:04 PM   #7
Personally I would use concrete. While moisture coming off concrete still happens it is of a very fine nature and readily mixes with air. Damp porous surfaces will pump a lot of moisture up as the ground warms up. Just make sure the concrete is graded so water doesn't puddle.
Old 09-27-2016, 02:40 PM   #8
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
CONCRETE
Old 09-27-2016, 04:49 PM   #9
Worst would be long, choking grass. Gravel I suppose might be ideal. But really, I think so long as there is good air circulation under and around the RV, things should be fine. I always trim our lawn very short, just before freeze up and before parking our Trillium. I had the frame Crown undercoated, inside and out, about three years and should do it again this. This year I will block the corners, put something under the wheels to spread the weight and (thanks for the idea) may put some poly underneath.
Randy J. is offline   Reply With Quote
Old 09-27-2016, 06:29 PM   #10
IllAnnoy
I like gravel, but storing outside should allow for adequate ventilation under the trailer, as long as water doesn't stand under the trailer.
Old 09-27-2016, 06:37 PM   #11
Best stay out of the trailer too.
Up to 60% of the human adult body is water. According to H.H. Mitchell, Journal of Biological Chemistry 158, the brain and heart are composed of 73% water, and the lungs are about 83% water.May 2, 2016
Old 09-28-2016, 05:47 AM   #12
Trailer: G30 Elite Class C
If u use Jack Stands,
:Make sure you cut some 3/4" Plywood squares to put under them so they do not sink down into Asphalt.
Stude
stude is offline   Reply With Quote
Old 09-28-2016, 08:28 AM   #13
Carl Pa's Avatar
Huhhh.
Carl Pa is offline   Reply With Quote
Old 09-28-2016, 03:27 PM   #14
james kent's Avatar
Trailer: Boler 1984
The doc calls it arthritis. Now I find out that I have rust.
Jim
Storing Toilet Paper Roll in Toilet-Shower Combo S Sato Plumbing | Systems and Fixtures 24 04-18-2015 12:46 PM
spiderweb like cracks on fiberglass surface jondsw Care and Feeding of Molded Fiberglass Trailers 4 11-12-2013 09:26 AM
Pantry organization- how are you storing your food? Bobbie Mayer Problem Solving | Owners Helping Owners 15 04-30-2008 03:38 PM
It just gets Better and Better james kent General Chat 5 11-26-2006 12:48 PM
Storing security Quint General Chat 4 01-16-2006 09:27 PM
