Old 06-03-2012, 09:30 AM   #1
Trailer: Looking
What is this thing on the outside of my burro?
I think this has something to do with the propane heater. It's sort of extended an inch or two on the outside of my burro. The problem is, it's chipped as you can see. How can I make it round again? Is there something I can sculpt that will harden and I can sand and it will look good? Or can I buy one somewhere? It seems like the first idea would be better because it's all of a piece.
Thanks!
jenbooks is offline   Reply With Quote
Old 06-03-2012, 09:58 AM   #2
Trailer: Fiber Stream
It is a cover to divert the airflow. Do you know the brand name and model number of the heater?
We might have something about it in the document center.
Old 06-03-2012, 02:25 PM   #3
Trailer: 1982 13 ft Burro
It's the outlet for the heater. Mine was also broken - I cut out a piece of plastic/vinyl sheet and reused the screws. Since it's the heater outlet, it does get hot and the plastic deformed a little, but it still works.
AndyW is offline   Reply With Quote
Old 06-03-2012, 02:27 PM   #4
Trailer: Looking
Thanks. I am thinking I could get some kind of moldable putty that hardens, some plastic type thing that hardens, and sort of sculpt it and glue it on. Maybe I"m crazy. But it's like having a chipped tooth on a nice set of pearly white teeth. There it is on the front of my burro. :-(
Old 06-03-2012, 02:32 PM   #5
cpaharley2008's Avatar
Trailer: 2012 Escape 19' with Ram Hemi or FJ Cruiser
I'd use a round piece of metal, painted. Go to hardware store and get a 4" round electrical outlet cover, made out of metal. May last longer being exposed to heat and elements.
Old 06-03-2012, 02:40 PM   #6
Trailer: Looking
Jim, thank you for that great idea. Will I drill holes in the metal for those screws? Remember, I'm a former New Yorker, a literary type, I have no clue what I'm doing neither does my partner! :-) And if I keep this little donkey for a while, I want to redo my cabinets, and want them white, and wonder what anybody recommends that is nontoxic and durable.
Old 06-03-2012, 02:55 PM   #7
Use the old one for a template and drill holes, use the original bolts.
Old 06-03-2012, 02:56 PM   #8
Trailer: Looking
Ok. We don't have a drill nor do we know how to drill holes but there's a talented guy at the RV park who builds houses so he'll know.
Old 06-03-2012, 04:14 PM   #9
Green Frog's Avatar
Trailer: '83 Burro
Virginia
Sounds like a plan, Jen. It will take less time to actually do the job than to go buy the steel cover plate, which will take less time than it took to get all of this figured out. Just be sure to be properly appreciative of your talented friend's work... perhaps a cool beverage or two of his choice will make the work go more smoothly!
Froggie
Green Frog is offline   Reply With Quote
Old 06-03-2012, 04:32 PM   #10
Jen:
Unscrew that lid, put it on a piece of cardboard, trace the largest chip. Then cut out the cardboard, trace the chip between every screw, get a jigsaw with a fine-toothed blade and duplicate the chip. Get a piece of 180 grit sandpaper and smooth the edges.
Screw it back on again. If that doesn't work I'd get creative with duct tape or WD-40. If that doesn't work I'd replace the muffler bearing.
Old 06-03-2012, 04:43 PM   #11
And you'll need a "wijjit' to handle that !!
RRJR is offline   Reply With Quote
Old 06-03-2012, 04:56 PM   #12
Trailer: Looking
I gotta admit, I don't even know what you're talking about, Per!
Froggy, I'll definitely pay him.
Old 06-04-2012, 05:03 AM   #13
Trailer:
Lazy suggestion - how about unscrewing that broken cover, rotating it half a turn and screwing it back on? If the broken edges were at the bottom, it might not annoy you so much.
Old 06-04-2012, 06:01 AM   #14
Trailer: Looking
Just curious why I can't do something like this:
Tips on Repairing Chips in China - Yahoo! Voices - voices.yahoo.com
burro
It's a Girl, thing! Robin G General Chat 157 05-06-2013 03:20 PM
i forgot the best thing.... sfoss Modifications, Alterations and Updates 8 03-18-2012 09:34 PM
What is the one thing (or two or three) that you cannot live without? Monica M Fulltiming in a Molded Fiberglass Trailer 43 04-16-2009 01:48 PM
Can I lock this thing??? Lynn L General Chat 13 06-09-2008 02:33 PM
The VERY next thing! Roger H General Chat 12 11-25-2005 10:27 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
