What to ask when buying a Boler? - Fiberglass RV
Old 06-07-2007, 06:22 PM   #1
Welcome to FiberglassRV, we're glad you found us!
To start, over on the left navigation bar under the "Tutorials" you'll see a Buyer's Check List, we suggest you print it out, go over the items and take the check list with you.
Ah, here's a shortcut, click HERE. As far as questions specific to that particular year of Boler, I'll leave that to others much more knowledgable.
Old 06-07-2007, 07:11 PM   #2
Rob S.'s Avatar
Trailer: 1980 Bolar 1700
Massachusetts
I'd start with the buyers check list in the Resource Document Center here on the site if you haven't already. You're going to get a list of things to check for as long as your arm from all of the helpers here. But, since I'm here first and own a 17' I tell you some of the things I encountered.
You are going to need to roll up your sleeves and crawl under the rig with a flash light to inspect the frame, plumbing, tanks, and gas lines. Really look at all of the welds on the frame from both sides to see if any are rusted out or cracked. Also look at the two main rails for any breaks, patches or major rust out. I'd recommend a small wire welding brush to clean off the rust and scale so you can inspect them properly. Oh and don't for safety glasses nothing worse that that stuff falling in your face. Check out the axle for bends, broken leaf springs (if applicable), shackles, etc.. Tanks and plumbing you're looking for cracks, breaks, etc. The collar around the water tank and the gray and black water tanks like to crack and split from age and the plumbing shaking on the road.
Inside look for water stains on the paneling of the floor cabinets and inside the uppers. Also check for heavy rusting on any of the "L" bracket that hold the cabinets to the walls and roof. This will tell you if there is a loose rivet and water leaking in. Fill the fresh water tank with a few gals and pressurize the system. If the pump is flipping on and off, without a faucet open, there's a leak somewhere.
Onto the floor. My Boler is a 1980 and has a full fiberglass belly with the plywood floor glassed into place on top of the belly pan. Other Bolers have plywood that has been fiberglassed, and there are probably other variations that I am forgetting or not aware of. In my case the plywood is sandwiched between the belly pan and the vinyl flooring making a nice non-breathable situation should water get in under the flooring. You want to check the floor thoroughly for soft spots or spongy places. I had two soft spots that I thought I would be able to do a quick splice and repair but once I started tearing up the vinyl the entire floor was wet through.
Check wiring for shorts or any loose cutoff wires, check lights etc. on both 12v and 110v. To answer you question about the Ice box, you should still have 110v shore power.
Check in some of the out of the way places for mold and mildew. Also check for rips or tears in the insulation.
I know I've forgotten things that others will expand on. The check list is good, use it. I had all sorts of things that I was going to look at on the 7 hour drive to get mine but when I got there I was so blurry-eyed with excitement I forgot about two thirds of them. Also all of the things I mention are not intended to scare you off your egg but to be aware of what you are getting and possibly negotiating a fair price should something be amiss. As many will vouch, you can pretty much do absolutely anything to these things and it all boils down to your skills, how ambitious you are, time and money. Got a hole in the wrong place? Glass it over and put it in the right place. Got a rotten floor? Tear it out and put in a new one. Holes in the frame? Build a new frame.
OK. I'll stop. Good luck. I hope it is exactly what you are looking for. They are great fun to play with.
Rob
Rob S. is offline   Reply With Quote
Old 06-08-2007, 09:49 PM   #3
Trailer: 1998 17 ft Casita Spirit Deluxe / Red F150 X-Cab
Thank you for all that great information--surely applicable to a person buying ANY trailer, not just a Boler. The checklist is great, but your expansion on it gives this newbie some specific problem areas to look for. Appreciate it!
Lisa M. is offline   Reply With Quote
boler
Help Buying New Axle for 75 Boler Michelle A Towing, Hitching, Axles and Running Gear 3 03-12-2010 07:17 PM
Boler: Buying it in Canada and getting it to the US JoelP Problem Solving | Owners Helping Owners 1 06-08-2009 08:35 AM
Plates, Paper Work, Buying Boler, Ontario Canada Cynthia MC Care and Feeding of Molded Fiberglass Trailers 5 09-03-2008 03:01 PM
buying replacement cushions for Boler and where to get propane tank MRowe Problem Solving | Owners Helping Owners 11 07-24-2006 05:18 PM
Buying a Boler Legacy Posts Problem Solving | Owners Helping Owners 2 05-08-2003 01:35 PM
