Wheel bearing grease seals - Fiberglass RV
Old 02-20-2013, 07:00 PM   #1
Trailer: boler 1974
1974 boler with the Henschen Dura Flex axles that are found on zillions of trailers. Packing wheel bearings as part of frame restoration. No numbers on old seals. Spent many days on the computooter and in parts stores with no luck. CAN SOMEONE HELP? Seeing as there are one of these axles behind every other bush I can't figure how it has been so impossible to look up seals to buy and install. What do you mean...frustrated?
BIG thanks in advance, Fred
fred boyle is offline   Reply With Quote
Old 02-20-2013, 07:08 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
You need to measure the inner and outer diameters. You can probably buy them at an auto part store. If not, then at a place like etrailer.com, for sure.
etrailer.com - Products grease seals
Old 02-20-2013, 07:30 PM   #3
I've found that wheel seal measurements can vary by a small amount, especially the outer diameter. I had to return a set because the outside diameter was off by about .010" from a stock seal. Fortunately I have an account with my local auto parts store that is independently owned and has a wider choice of where they can get parts, and more knowledged parts guys than the franchise stores, so there was no problem in getting the correct size seal. Because of this issue, I recently bought on eBay a vintage assortment of wheel seals, so I'll have better luck when I need a seal. I'll have several sizes to go through and try, and the boxes have the part numbers on them. This will make my life easier as I have four campers, four utility trailers, and a boat trailer. You need to find a parts store where they can measure a seal and have the books to look up what you need.
mary and bob is online now   Reply With Quote
Old 02-20-2013, 10:34 PM   #4
Trailer: Trail mite
Idaho
You can also bring the seal down to an industrial supplier like Kaman Industrial Technologies or any of the other brand x's. We size up many trailer bearings and seals a week at my location. I would be more then happy in helping you figure this out. Especially if you have the bearings identified already. Most of the time there are about 3-4 common sets of seals and bearings
Gr8WhtHunter is offline   Reply With Quote
Old 02-21-2013, 04:53 AM   #5
Trailer: 2014 Escape 21
Virginia
Redneck Trailer, Check out page 39 for seal info./sizes.
Eddie
http://www.redneck-trailer.com/Porta...nt/files/B.pdf
Buying grease seals online Raz Towing, Hitching, Axles and Running Gear 5 10-29-2011 01:53 PM
Bearing Grease Lifespan melissab Towing, Hitching, Axles and Running Gear 6 05-14-2011 12:36 PM
Size of wheel bearing seals - Bigfoot Carol Crawley Towing, Hitching, Axles and Running Gear 8 06-14-2010 11:03 PM
Wheel seals for 1974 trillium 4500 Jet Rosas Towing, Hitching, Axles and Running Gear 8 04-29-2008 04:00 PM
Bearing Grease Legacy Posts Care and Feeding of Molded Fiberglass Trailers 9 06-21-2003 07:41 PM
