Why not just level with a jack? - Page 3 - Fiberglass RV
Closed Thread
Old 06-03-2015, 10:16 PM   #29
deryk's Avatar
New Jersey
I think most of us carry a few things for leveling a trailer side to side depending on the situation. I have a few 2x8 boards and a set of Lego blocks and a BAL. If it is only a little off a board usually does it, if 1 board isn't enough it's Lego time and if it's more then that I use the BAL, or have to disconnect from the trailer. The BAL is a great tool to have for leveling your trailer and built in chock lol.
deryk
deryk is offline
Old 06-03-2015, 10:38 PM   #30
tractors1's Avatar
Trailer: Escape 21 - Felicity
Originally Posted by Randy P. View Post
Byron you specifically highlighted Timberwolf's comment in regard to potential axle damage then providing a link that supposedly buttressed your position. It doesn't.
But, I do not agree with jacking on the axle damaging anything. The axle is a tube set up as a diamond shape and it seems HIGHLY unlikely it could be damaged by jacking anywhere near the ends
Of course Dexter doesn't want you to do something that is unsafe but it doesn't imply or state that damage is the reason for the warning. Again, it's a safety issue and should be respected as such. I don't disagree that it's a bad idea but there's no need for you to be insulting, jeesh.
The bent Dexter axle I helped replace had very little wall thickness surrounding the rubber pieces used for torsional damping. NOT a strong beam as it appears; you crimp a corner of the diamond and the strips won't rotate freely anymore.
Charlie Y
Charlie Y
tractors1 is offline
Old 06-03-2015, 11:09 PM   #31
The better way would be to use Legos under the low wheel. Wheels can and do slip off of wood when the wood gets wet in rain.
been there done that and having the trailer slip off wet wood is not fun! Lego blocks weigh far less and take up less room than wood. Not to mention much cleaner to carry with you - just put them in the nylon zip pouch they come in.
While the BAL is nice to have if you have the room, unlike the BAL the Lego blocks are a multi use item. They are handy for other things as well. Putting under rear stabilizers & front tongue to stop then from sinking into the sand or gravel. I have used them for levelling a portable table & BQ, as well as a step into the trailer. A pack of 10 is less than $25.
Carol H is offline
Old 06-04-2015, 05:57 AM   #32
theresa p's Avatar
New Brunswick
Thumbs up
I'm with Randy---the Anderson leveller is fantastic! No more going back and forth trying to get it right....just one time going backward and it levels. Bingo. Excellent product. Used it all last summer and won't go back to wooden boards or the lego blocks.
theresa p is offline
Old 06-04-2015, 08:17 AM   #33
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
I've used lego blocks, boards, etc but once I tried the Anderson Leveler, I never went back. Fast & easy!
Jon Vermilye is offline
Old 06-04-2015, 08:31 AM   #34
Randy P.'s Avatar
Trailer: Casita Spirit Deluxe
I also like the fact that it's compact and fits nicely in the side storage compartment.
Randy P. is online now
Old 06-04-2015, 08:40 AM   #35
Trailer: 2015 Scamp 13D
Last night I sent Dexter Axels an email that asked: "Do you know if there is any danger to your axel if one uses the BAL wheel leveler device to level the trailer for short term camping trips (weekends, not months of storage)?"
Their reply was: "Lifting the weight of the trailer by any of the running gear suspension is not recommended."
So what is the physics of blocking one side of the trailer at a different level than the other? Should we always revert to using a frame jack to level?
Rich G. and Val F. is offline
Old 06-04-2015, 09:10 AM   #36
tractors1's Avatar
Think about that lawyers reply..... Doesn't the torsion axle lift the weight of the trailer whenever you drive over bumps? I'm also a big Andersen leveler fan.
Charlie Y
Old 06-04-2015, 09:13 AM   #37
What's the difference between lifting a wheel on a BAL, running it up on blocks, or towing it over a bump? The wheels are the one component that is designed to carry the full weight of the trailer. Either they misunderstood your question, or we are misunderstanding their response, I think.
Jon in AZ is online now
Old 06-04-2015, 09:13 AM   #38
Quote: "Their reply was: "Lifting the weight of the trailer by any of the running gear suspension is not recommended." (italics added)
Read between the lines.... lifting by the tire IS NOT a lifting by any part of the suspension, after all, it rides 1000's on miles on those tires.
Trailer-wise there is no difference between a BAL leveler and a set of blocks or a ramp.
Bob Miller is offline
Old 06-04-2015, 09:17 AM   #39
Jon, I agree with you & the other users of the Anderson that it really does look like its the best option for levelling - can't get any easier than that!
Sadly will our falling loonie and the cost of shipping north I may have to have to wait and add it to my wish list from Santa next year and hope their elfs know about it! A bit surprised their have not been any knock offs made of it yet...
Carol H is offline
Old 06-04-2015, 09:42 AM   #40
David Tilston's Avatar
I am not sure why no one has mentioned the obvious. I have a pair of support jacks on the back of my trailer. I drop the tongue till the coupler is almost in the dirt. I deploy the rear jacks, eyballing the slope of the ground and adjusting the jack length to compensate. If the ground is soft, then I put down some lego blocks. Then I lift the tongue till the trailer is level, front to back. I usually get it within half a bubble left to right. If not, drop the tongue and try again.
David Tilston is offline
Old 06-04-2015, 09:47 AM   #41
IllAnnoy
Well said!
floyd is offline
Old 06-04-2015, 09:55 AM   #42
I did that once, David, and it's the reason I realized I needed the leveling blocks. Unless both stabilizers are firmly planted on the transverse slope when you start raising the tongue (in which case there is no side-to-side leveling effect), there will be a twisting force on the frame. By most accounts and my own observation, that's not a good thing.
Closed Thread
Not fiberglass, but why not wooden trailers? John Linck General Chat 68 03-10-2018 12:58 PM
Tongue Jack Stand fits 2" jack FTTRV Commercial Posts and Products 7 06-20-2014 08:53 AM
How level is level? Cam A Care and Feeding of Molded Fiberglass Trailers 29 05-27-2014 06:58 PM
Fixing bubble level on Electric Tongue Jack! Michael Pupeza Problem Solving | Owners Helping Owners 1 09-24-2010 05:10 AM
How level is level? DaveK Problem Solving | Owners Helping Owners 8 06-06-2007 11:03 AM
