Window treatment ideas wanted.... - Fiberglass RV
Old 06-06-2011, 07:45 PM   #1
cpaharley2008's Avatar
I'm thinking of changing the standard venetian blinds in my camper. I notice the new Trillium has wooden blinds. I see some owners have curtains, thinking about woven shades. I want something that will allow ventilation as well as privacy. The other issue is ease of mounting, I have a bulkhead over 2 windows but not over the third. Thanks for any suggestions, pictures would be appreciative, they are worth a 1000 words.
Old 06-06-2011, 08:12 PM   #2
Trailer: 2015 Escape
Along those same lines, I'm thinking about getting rid of the blinds and am wondering how some of you hang your curtains. Thanks.
rgrugg is online now   Reply With Quote
Old 06-06-2011, 09:03 PM   #3
Roger C H's Avatar
Smile Wooden Blinds?
I'm thinking of changing the standard venetian blinds in my camper. I notice the new Trillium has wooden blinds. ....
I think you are mistaking day/night shades for blinds.
trilliumrv.com
Old 06-07-2011, 07:43 AM   #4
Trailer: 13 ft Scamp
We have valances hung on the standard curtain rods, plus auto sun shades cut to fit and lined with fabric on the inside (foil facing outside). The valances allow lots of light and air, and the shades (adhere with velcro) block the light for sleeping or privacy needs. We like not having anything hanging in the way and these fit that bill.
Darnelle is offline   Reply With Quote
Old 06-07-2011, 10:20 AM   #5
Trailer: Fiber Stream
Previous thread link on this subject
Roman shades vs curtains
Old 06-07-2011, 06:41 PM   #6
Penney H. & Mike E.'s Avatar
Trailer: 2005 17 ft Escape ('Turtle')
curtain hanging
I posted some pics on another thread of our curtain hanging:
Black Out Curtains
This thread went off in different directions from just black out ideas, as many threads do. You can probably find curtain ideas and hanging suggestions on other threads if you do a search.
Penney
"A good traveler has no fixed plans and is not intent on arriving." -- Lao Tzu
Enjoy our travel photos at: Turtle Travels
Penney H. & Mike E. is offline   Reply With Quote
Old 06-07-2011, 06:42 PM   #7
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
Bath towels from Chinamart secured to rods with "claw" rings at three windows in aft dinette/sleeper. Worked well at side windows as rod holders can be screwed to underside overhead locker. Not so great in the great "proscenium arch" above the Burro rear window. Rod hangers had to be attached to inside window frame which puts "curtains" a bit low to block lite at top. Should add grommets at same intervel as the rings which would put material slightly above rod and block lite. OK, it wasn't exactly a house-beautiful idea but it was cheap and my wife won't ask me why I'm wiping my hands on the "curtains" hardy har har. We have nothing at the window of the smaller front dinette (which is now permanent with el cheapo swiveling boat seats atop the lockers in place of cushions). Rock guard there blocks lite so as new owner who is rather busy correcting and fitting out, I'm not looking to correct problems I don't have.
jack
Old 06-07-2011, 07:00 PM   #8
A no-thru-the-shell solution for hanging curtain rods:
Old 06-09-2011, 04:11 PM   #9
Trailer: 2007 Eggcamper
I simplified. Got rid of the blinds (too much trouble putting them up and down all the time because of the dogs). We bought a vinyl coated table cloth to sort of match sheets, cut it, sewed it (as best as I could ha ha), and just fastened them up with velcro. Now it is quick and easy to open and close curtains. (AND MUCH LIGHTER)
Art
artspe is offline   Reply With Quote
Old 06-09-2011, 07:47 PM   #10
Pam Garlow's Avatar
Trailer: U-Haul 1985
Donna, What a great idea! Is the black metal piece only riveted to the window frame? And this would not get in the way of closing the slider window?
Old 06-09-2011, 08:02 PM   #11
Pam, it's not mine. I've had the pic for several years and don't know where I got it... but yes, the bar is riveted to the clamp ring only. I'm thinking you could angle it a bit and put a longer curtain rod on which would allow the curtains to move all the way away from the window for better viewing.
Old 06-10-2011, 04:17 AM   #12
Ron F's Avatar
Trailer: Eggless for now.
Formerly NH, now full timing
Bob,
I found plastic tracks at Camping World that I mounted at the top and bottom of each window, using a few of the screws for the window frame itself. After sewing up some curtains, I attached the mating slides (also from CW) to the top and bottom of the curtains. The slides come on a strip of thin plastic that you can just sew to the back of the curtain. The white strips at the top and bottom are the tracks.
These photos probably don't show the hardware well enough. I'll see if I can get better photos that will explain it better.
Ron
Old 06-10-2011, 07:53 PM   #13
Here are mine - they have thermo lining on the back to block out light
Old 06-11-2011, 08:10 AM   #14
Other than Donna D. I'm having trouble figuring out how to mount curtains or blinds or whatever to an all fiberglass interior. Maybe I just glue some wood around the frames that wouls allow mounting brackets?
Wanted window knob for Scamp Brian Bran Wanted: Molded Fiberglass Travel Trailers 4 05-19-2011 02:39 PM
Ideas Wanted - New Propane Install Bill Robison Problem Solving | Owners Helping Owners 59 05-09-2011 04:45 AM
Help with UHaul Window Awning Ideas Gary P Problem Solving | Owners Helping Owners 0 10-17-2009 10:01 AM
Wanted - Side window for 13' Boler ecasey Classified Archives 0 06-26-2007 02:59 AM
Blackwater treatment Kevin F Care and Feeding of Molded Fiberglass Trailers 5 07-11-2006 08:39 AM
