wintering of battery and propane tank? - Page 2 - Fiberglass RV
Old 10-21-2015, 01:24 PM   #15
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
Originally Posted by M Scott View Post
Recommendations for how to store my new battery and propane tank over the winter months? I will be covering my Scamp with it's canvas "suit" and placing it under commercial roof-covered storage.
Recommendations for the new battery and propane tank? Do I leave them on the trailer (disconnected), or remove to an enclosed garage (not too keen on propane tank stored next to my car in tiny garage)? Weather predicted to be warmer this winter (El Nino) in Pacific NW but more rain.
Appreciate all responses. Thanks.
No need to fret about the battery. As another one said, a fully charged battery will not freeze. Just make sure the top of it is clean and dry. And you can disconnect the negative cable to be sure there is no trickle load on it.
The propane bottles stay hooked up and shut off.
Old 10-21-2015, 02:25 PM   #16
Trailer: R-Vision Trail Lite
Never store a propane tank indoors. You will find it is a violation of the Fire Codes in most states. Insurance companies will void your policy and deny claim if evidence of a propane tank is discovered after a fire loss.
Leave your propane tank on the trailer in a well ventilated location...valve off.
Uplander is offline   Reply With Quote
Old 10-21-2015, 03:55 PM   #17
Trailer: scamp 16 [front bath]
Marilyn,
Below is a link to a 10 watt solar panel with a PWM controller and the necessary connectors to keep your battery charged all winter. Just disconnect your trailer wiring, connect this to your battery, set the solar panel out in the sun and you're good to go for the winter - and the price is right [$50 from Amazon]. Moreover, it will be available during the summer to "help" with maintaining your battery while camping.
Rick
Instapark® NEW All Black 10W Mono-crystalline Solar Panel with 12V Solar Charge Controller
rick in arvada is offline   Reply With Quote
Old 10-21-2015, 05:31 PM   #18
M Scott's Avatar
Trailer: 13 ft 2005 Scamp Deluxe; 2002 Subaru V6 Outback
Darral: is this the unit you suggest? Amazon Battery Tender 021-0123 Battery Tender Junior 12V Battery Charger @ $24.95.
I looked at Battery Tender.com and they can't ship these to CA or OR.
Would you leave it plugged in 24/7?
M Scott is offline   Reply With Quote
Old 10-21-2015, 08:00 PM   #19
IllAnnoy
Charge the Battery
clean the top
place a shower cap over the top
place on a shelf
retrieve in the spring.
The battery should hold a charge as long as there is no conductive path from the positive to the negative posts. Cleaning the top will pretty much accomplish this, and the shower cap will pretty much keep the battery top clean.
Old 10-21-2015, 11:31 PM   #20
Yes, that's the one. I own three of them. I have one on a model airplane toolbox battery (gel cel), one on my riding mower and one on my Scamp as I type. It stays plugged in 24/7. I've lost a couple of batteries (not the Scamp) because of lack of use through the winter. When these chargers are in "maintain" mode, they pull VERY little current.
In the past, I would go down about once a month during the winter and plug in my Scamp for a day or so to make sure my battery stayed topped off. But I dont with this charger. The led is red when it's charging. When it gets near the max charge, it will start blinking green. When the led is solid green, it's in a "maintain" mode. The instructions that come with them explains it thoroughly.
Alot of people will use cheaper chargers like from Harbor Freight. I personally dont trust them- I do the Battery Tender. Again, the warranty speaks very well for this product.
Old 10-22-2015, 07:45 AM   #21
Trailer: Oliver
For what its worth - I totally agree with Darral. I've used a Battery Tender on a motorcycle battery for a touch over seven years now and it is still going strong. Simply plug it in and forget it (almost). I do check the fluid level in the battery once or twice a year just to make sure.
Bill
topgun2 is offline   Reply With Quote
Old 10-22-2015, 09:25 AM   #22
Bob in Mb's Avatar
Trailer: Surf-Side
Manitoba
Very important - should there be a fire in the building the tank will go off like a bomb - very dangerous for those fighting the fire !!!!
Bob in Mb is offline   Reply With Quote
Old 10-22-2015, 11:33 AM   #23
M Scott's Avatar
For anyone interested in the Deltran battery tender, there is an Oregon & California approved version for $29.95.
Last winter I stored a battery and found it dead this spring and had to replace it.
Thanks everyone for your suggestions...I'm going with a battery tender from now on.
Old 10-22-2015, 12:43 PM   #24
Thank you M Scott for pointing that about about the Cal/Ore models. That information may prove helpful to others as well.
[QUOTE=M Scott;555029]For anyone interested in the Deltran battery tender, there is an Oregon & California approved version for $29.95.
Old 10-22-2015, 07:10 PM   #25
IllAnnoy
It will vent just making a bigger fire.
So do you store all your aerosol cans out doors?
What about your MIG,cutting torch, propane torch, lawn mowers, cars etc?
Store them all outdoors?
Old 10-22-2015, 07:20 PM   #26
Creating yet another flame war?
Old 10-22-2015, 09:54 PM   #27
tractors1's Avatar
Trailer: Escape 21 - Felicity
I lived in Wisconsin with no natural gas. In winter our 200 gallon propane tank used for heating the house and cooking was just fine even buried halfway up the sides in the snow. Kinda looked like a long skinny igloo, actually.
Charlie Y
Old 10-23-2015, 04:34 AM   #28
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
My preference is to leave the propane and battery on the trailer. Just shut the valve on the propane, and ensure the battery is fully charged. If you have no way of running electricity out to the trailer, you could just check the voltage to make sure you are near or over 13V, and all will be good. If it was to start dipping, you might want to bring it in to connect to a smart charger. CTEK has some good ones too.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
battery, propane
Wintering in the Phoeniz area Richard K. Camping, Campout Reports 3 03-08-2014 01:22 PM
Propane usage (T off the trailer tank or take a spare tank) knighth001 Problem Solving | Owners Helping Owners 13 09-20-2012 06:37 AM
modify hitch to hold propane tank, battery and generator. Susan A Towing, Hitching, Axles and Running Gear 9 04-15-2012 07:34 PM
Propane tank / Battery mount Trillium 4500 1978 Gumpit Modifications, Alterations and Updates 14 11-20-2010 09:15 AM
