Winterizing - Page 2 - Fiberglass RV
Old 10-07-2006, 02:04 PM   #21
Alf S.'s Avatar
Everything is perfect except this :
You should never put any kind of stress on the frame. Keep it on wheels.
And this :
Yes that would cause stress and particularly uneven stress which is even worst. That would also be bad for your refrigerator.
Hi: What about changing wheels and tires for a pair of compact spares from the wreckers. As long as the bolt pattern is the same...leave the trailer on wheels for the winter!!! Alf S. North shore of Lake Erie
Old 10-07-2006, 10:40 PM   #22
Gina D.'s Avatar
Where can I buy a Gnats Hair for my drain
You have to harvest them on your own.
First, go get a LITTLE set of clippers.....
Old 10-09-2006, 06:05 AM   #23
Alf S.'s Avatar
Hi: Sorry Gina...I only have a pair of Geezer Tweezers to pull out whats left of MYYYYYYYYYYYYYY hair!!! I'd have lots of hair if it was in a bowl of soup... Alf S. North shore of Lake Erie
Old 10-09-2006, 07:14 PM   #24
Trailer: 87 13 ft Scamp
As I read through this, water is the real issue. I've never put water in any of the tanks. So is leaving the SCAMP outside during the winter all bad? Have some done it w/o a problem? I do plan to remove all food products. But I am thinking about using the SCAMP a couple times during the winter. Even if it is just an over-night to do some xc skiing up north. I'm in MINN. Thanks for your thoughts in advance.
Steve B is offline   Reply With Quote
Old 10-09-2006, 07:26 PM   #25
Brian B-P's Avatar
Steve, although some members of this forum are fortunate enough to have a garage which can accommodate their trailer, I think very few RVs of any kind are stored indoors over the winter in this area - and we do get real winter. If there is no water in the plumbing, and snow loads on the roof are managed, I don't see a problem.
My B1700 has probably never seen the inside of a building, other than when it was made and when it has been into RV dealerships (or car washes) for maintenance. I have an open-sided shelter - still to be assembled - and if the Boler fits I'll put it under there; however, there's little chance I will ever have a garage for it.
Old 10-09-2006, 08:11 PM   #26
Roger H's Avatar
Steve, my Scamp 16' lived outside all last winter. It didn't complain at all.
While my 25' trailer will enjoy being in enclosed storage for the winter, my 17' trailer will stay outside at the house and get used!
Roger
Old 10-10-2006, 03:28 PM   #27
Trailer: Scamp 16 ft
Roger, I too have been wondering about what to do with my 16 ft scamp for the winter. We purchased it 2-1-06 and it sat out side since then. Do you think it is neccesary to store them indoors fro the winter? My only real concern might be the snow weight and how to deal with that.
Dan B is offline   Reply With Quote
Old 10-11-2006, 07:08 AM   #28
Roger H's Avatar
Use Gel-Gloss on it twice a year, once in the spring and once in the fall. Wash it regularly and it'll be fine outside. The roofs in those built in the last fifteen or so years are all braced for A/C units. They won't accumulate enough snow to be a weight problem.
Roger
Winterizing Aid Steve L. Modifications, Alterations and Updates 1 04-26-2009 03:03 PM
Winterizing Bigfoot Mike Care and Feeding of Molded Fiberglass Trailers 0 10-11-2006 10:32 AM
Winterizing stevenff Problem Solving | Owners Helping Owners 7 11-29-2005 08:51 AM
"De"- winterizing Legacy Posts Care and Feeding of Molded Fiberglass Trailers 6 06-05-2003 02:44 PM
Winterizing Legacy Posts Care and Feeding of Molded Fiberglass Trailers 10 09-20-2002 09:09 AM
