Wiring Adapter? - Fiberglass RV
Old 06-20-2003, 03:13 PM   #1
Wiring Adapter?
The trailer I just bought has electric brakes and needs "a round plug" according to the current owner. Our Nissan Xterra has the flat 4 post connector. Is this http://www.reese-hitches.com/wiring_adapters.htm#4-Way what I need to be able to pull the trailer and have the lights on it work? I understand the brakes won't work with this. I don't want to fork out the $$$ right now to get the brake thing going, but I do want to pull it soon!
Thanks! - Jeremy :wave
Old 06-20-2003, 03:32 PM   #2
4-way to 7-way adapter
It's most likely a 7-prong round that is on the trailer now.
The first adapter (the 4->7) is the closest to what you likely need. However - it's really pretty easy to make the adapter you need yourself by just buying the two connectors (7-way car end and 4-way trailer end). The only trick is making sure you hook the wires up right. :)
I had to do this the other week when I went to pick up our new trailer. I initially shelled out the $25 for the adapter, only to find out even THEY didn't bother hooking up the ground wire! I returned it and bought the raw components I needed to hack together the adapter. After some initial worries about what wire went where - it took about 5 minutes to put together.
mkw
Old 06-20-2003, 03:37 PM   #3
use your 4 pin
you can make an adapter or splice a 4 wire plug into existing wireing on trailer. no brakes no auxillary power .
running turn and brake lights will work.
I have towed my trillium without brakes once that was its trip home.
Brakes are very nice to have. Heare in Va tourist area it is next to impossable to leave extra stoppimg distance between cars some one always pulls in ahead of your saftey zone .enough said
have a fun summer of egg-ing it
Al
Old 06-20-2003, 06:21 PM   #4
Connect the Brakes
Hi Jeremy
Get a brake controller! Don't tow without connecting the brakes.
I've towed my Scamp with and without connecting the brakes. I will never tow it without connecting the brakes again.
If you want to see how the regular Scamp trailer wiring is connected, see my web site and click on "Manual".
-- Dan Meyer
http://scamp.n0kfb.org/
need adapter 13 scamp BarryS Towing, Hitching, Axles and Running Gear 4 08-17-2009 03:40 PM
Four-prong flat to seven round wiring adapter Adam S. Classified Archives 0 07-03-2009 05:05 PM
Help find a 30 amp (Hubbell twist lock) to 15 amp adapter rudock1 Problem Solving | Owners Helping Owners 10 12-14-2008 12:36 PM
RV Wiring Darwin Maring Problem Solving | Owners Helping Owners 8 01-27-2007 04:45 PM
Power Caster Adapter Legacy Posts Modifications, Alterations and Updates 2 02-05-2003 01:15 AM
