Wiring Safety - Fiberglass RV
Old 08-16-2006, 11:54 PM   #1
Something was said on the forum about electrical safety. I don't think I've ever seen here anything brought up about what kind of wire to use. Actually the insulation is the important part. Most wire you purchase at Wal-Mart, Radio Shack, etc. is insulated with vinyl. Automotive wire is insulated with Teflon.
It matters because;
1. Teflon will with stand a much higher temperature before if will burn than vinyl will.
2. Teflon is much more resistant to abrasion, thus is less likely for the condutor to be exposed.
There are primarily two Teflon insulations called out in SAE specifications. SAE is Society of Automotive Engineers. One is refered to as GXL, the other SXL. GXL stands for General purpose cross Link, SXL stands for Special purpose cross Link. (X = cross, cross link = Teflon).
The difference between the two is the thickness of the insulation. SXL has thicker insulation than GXL thus SXL will take more abrasion than GXL. The SAE specification number that calls all this our if J1128.
What all this means that I would recommend that when doing any vehicle wiring you use wire with Teflon insulation. If it's marked J1128 GXL or SXL you know it meets automotive industry standards.
What's important is to NOT use vinyl insulated wire if you can avoid it.
Another thing on wiring safty -- The biggest cause of problems is poor connections. Poor connections a best will cause something to not work, or not work all the time. At worst a poor connection can get hot. Make sure your connections are solid. Are your crimp type connections good? An easy test is attempt to pull a crimp connection apart. The wire should break before the connection fails. I would never put a wire under a screw. Put a crimp lug on the wire, then the lug under the screw. I wouldn't recommend soldering connections unless you've had some type of soldering instruction and have done some soldering.
Last, but not least, use the proper size wire. It's ok to use a larger wire than required but not a smaller. Larger gauge number = smaller wire diameter.
Interesting side note on wire size. PACCAR, maker of Kenworth and Peterbilt trucks, won't allow anything smaller than 18 gauge in their trucks. There are times when a 30 gauge wire is more than large enough, but 18 gauge is use.
Safety
Old 08-17-2006, 12:14 AM   #2
Bigfoot Mike's Avatar
Trailer: Bigfoot 25 ft
Thanks Byron, good info.
Old 08-17-2006, 12:49 AM   #3
Appreciate the information, Byron. I routinely use automotive primary wire for my trailer, and try to err on the "hefty" side. My knowledge is still somewhat limited, so maybe you could clarify one little mystery (or rather gap in understanding) for me?
I have been trying to make my frig work acceptably on 12v for traveling but without luck. The element checks out to the 1.4 Ohms prescribed by Dometic. I measured the voltage at the frig with and without it being on and discovered approx. 1.5v drop. Then I replaced the entire run of incredibly thin 14 gauge with the recommended 8 gauge and yet I measured the same drop. I'm sure I'm not understanding how to measure voltage drop correctly, so where am I going wrong? (I have not had the opportunity to test the changed wiring/element out on the road yet but I am not very optimistic.)
Dometic says the 12v is just a "holding action." I should be so lucky.
Old 08-17-2006, 07:58 AM   #4
John & Sandy M's Avatar
Trailer: 1999 Scamp 16 ft
A crimp-on connection is a lousy way to join two wires... particularly in any application where the connection is exposed to any adverse environment (eg. automotive/trailer electrical). I learned this the hard way with marine electrical connections... the wiring oxidizes to the extent the connection is lost and the equipment fails. Even worse, the corrosion works up the wire under the insulation.
Soldering is not rocket science and a few practice connections will get you up to speed. I had the electrical work done on our tow vehicle at a local RV shop in prep. to pick up our Scamp last year. The left turn signal failed about a month later. I went through every connection made and removed the crimps. Removed about an inch of insulation from the original wire (did not cut). Did the same for the trailer connection splice and slipped on a piece of shrink tubing. I spliced the connection and soldered. I wripped the soldered splice with electrical tape starting with the original wire and then back up the trailer splice. I slipped the shrink tubing down the trailer splice and over the end of the electrical tape. I heated the tubing to shrink it around the end of the electrical tape so it can't come loose. This is the same splice connection I've used on my boat and trailer used exclusively in salt water and have never had a failure (after 15 years).
John & Sandy M is offline   Reply With Quote
Old 08-17-2006, 08:45 AM   #5
A properly done crimp connection is reliable. Soldering done by somebody that doesn't know how to properly solder might or might not be a reliable connection. Every connection in your automobile is a crimp connection. I think that says something about crimp connection reliablility.
Soldering is not rocket science, but it take practice and a bit of knowledge. You need to know a good solder connection looks like and to know what good technique is. Of course what goes along with what a good solder joint looks like is what bads ones look like. One of my other hats is soldering instructor. Before I turn anybody loose on soldering on a product we sell they make sometimes hundreds of practice connections. That depends on how long it takes them to get the feel of it. You may have been able to pick it easily, or you may have just been lucky.
Speaking rocket science and soldering. The last I hear to get certified by NASA to solder on rocket components required a 1 onth, or a 2 month soldering classs. I don't remember know remember for which. So maybe it is rocke science.
Old 08-17-2006, 09:42 AM   #6
I just thought of something else about solder connections. John did the right thing when he added shrink tubing, however wire movement when taping could cause wire strands to break. You'd never know untill the connection got hot. It's not a bad idea to put shrink tubing over crimp connectors, too. The shrink tubing acts as a strain relief when reduces breakage at the crimp or the solder joint. Soldering does on more thing, the strands of wire become brittle at the edge of the solder. The shrink tube will reduce movement at the edge of the joint and help prolong the connection's life. A shrink tube with adhesive inside will also improve the joint, either crimp or solder.
Old 08-17-2006, 09:45 AM   #7
Per, are going to be at the Northern Oregon Gathering? If so I'd be happy to take a look and see what I can find.
Old 08-17-2006, 01:38 PM   #8
Byron:
The Gathering is very much in doubt for me at this point. In the meantime I'll be looking for ways to make sure I understand how to measure voltage drop. That's where my knowledge gets a bit fuzzy. Who knows, maybe the change to 8 gauge wires (ground and hot) will end up to have made a difference in real life testing anyway. Thanks!
Old 08-17-2006, 01:56 PM   #9
Byron:
Darn, we're gonna miss you and frig trailer.
There's only one real way to measure voltage drop across a piece of wire or anything thing else. That's one meter lead at each end of the wire.
However you can get pretty close by;
Measuring the voltage at the frig with it off then again with it on. Then measure at the battery with the frig on and then with it off.
If the "entire run" doesn't go all the way to battery and there's a smaller wire between the battery, the smaller wire will account for most of the drop. It's kind of like trying to feed a 12" pipe with a 1/2" hose, you'll never get the 12" pipe full.
Hope this helps a bit.
Old 08-17-2006, 11:08 PM   #10
Pete Dumbleton's Avatar
Umm, a fuse is a short piece of smaller "wire" inserted in the larger wire.
One thing to NOT do is tin or solder wires and then crimp them or put them in a screw connection -- Over time, the pressure on the wire will cause the solder to "cold flow" and the connection will become looser.
Liquid electrician's "tape" is a good way to seal connections (Or SCUBA wet suit glue, for that matter).
Old 08-17-2006, 11:48 PM   #11
Yup. The amout of current is still restricted by the smallest wire which should always be the fuse. However if there's two pieces of wire in the system and the system if fused for the larger wire, you will still be restricted to the smaller wire. If pushed the smaller wire will get warm and pushed too much will burn.
If it's still not clear I can try again.
Old 08-18-2006, 09:18 PM   #12
We were talking about voltage drop across a length of wire. Here's a site that has chart and calculator to calculate voltage drop.
Enjoy.
Old 08-18-2006, 11:02 PM   #13
I guess the point I was trying to make is that the voltage drop is indeed a function of distance, so I believe the end result of charging a battery over a long large wire plus a short small wire will be different than a long small wire plus a short large wire.
In my case, I have a long large wire from the truck battery to the bumper connector and then the relatively short factory wire from the connector to the battery on the trailer tongue. Clearly, I'd be better off with large wire all the way, but I know the battery gets more fully charged than it would with truck wire the same size as the trailer because the final fill on the battery is dependent on the voltage, not the amperage (the amperage has more to do with how long the charging takes).
I believe amperage is equivalent to flow in hoses, and voltage is equivalent to pressure.
Without doubt, when it comes to low-voltage wiring, bigger gets the job done better.
Old 08-19-2006, 07:09 AM   #14
There are huge differences in crimp connections. The ones on your tug are made by machine. Vehicle manufacturers build a wiring harness (or loom) totally by machine, not by hand (okay maybe a hand-built car like the LaNay hand builds the harness.) A good friend of mine who works for a Chevrolet dealership, told me that he believes the reason why vehicle manufacturers use crimp connectors, rather than solder the connectors, is they're cheaper to fix...in today's economy that makes sense to me.
Just like learning to rivet, there is a learning curve to make a good crimp connection. Most often people buy an El-Cheapo crimping plier and even a cheaper box of connectors...then they wonder why they have wiring problems.
Safety bar for top bunk bed Rob Carmody Problem Solving | Owners Helping Owners 4 06-02-2008 10:22 AM
RV Safety Bruce B. General Chat 6 02-14-2008 08:50 AM
Gas Safety Taylor General Chat 4 05-30-2007 03:43 PM
Safety Tip Toodie General Chat 3 08-24-2006 08:09 AM
Safety Tip Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
