wiring.....there, I said it. - Page 2 - Fiberglass RV
Old 09-29-2016, 12:40 AM   #15
Typo, I meant locking the gates😝--the park closed at dusk!
Glad u got the problem solved--happy camping.
Lise in WA
LiseKen is offline   Reply With Quote
Old 09-29-2016, 04:53 AM   #16
Raz
Raz's Avatar
Vermont
Why did the fuse blow?
Raz is online now   Reply With Quote
Old 09-29-2016, 06:28 AM   #17
CampyTime's Avatar
Trailer: Scamp 13' Standard
First thing and easiest to check is a fuse. $98 to pull old fuse out, see that it's blown and pop a new one in is outrageous. And if it took them all day to figure out that they should look at the fuses again, I would caution You to consider going elsewhere.
Sent from my VS985 4G using Fiberglass RV mobile app
Old 09-29-2016, 08:52 AM   #18
Glad you got it fixed.
However, I can't think of a magic fuse in the cab of your jeep that would cause brake lights and tail lights to stop working on your RV, while side marker lights still work.
One thing I would do is get them to show you where this fuse is, pull it out and see if this really puts your trailer back into the same trouble.If it does then get a few spare fuses because you will most likely need to replace it again. Fuses usually don't just fail, somewhere you most likely have a short in the wiring and it can be a real hard thing to find. Might only short out when the RV is bumped or twisted just the right way. If the short is gone when you take it into the shop they won't be able to find it. If this was my trailer I would get a meter and test out the wiring right now while it is fixed. Then when it fails again (and it will) retest your wiring again. Even if you can't fix it yourself, when you take it in, they will have a starting point to work from.
Phoneman is offline   Reply With Quote
Old 09-29-2016, 04:51 PM   #19
Trailer: 2000 16ft Scamp
I think what happened to blow the fuse was when trying to pug the seven blade connector to the Jeep one of the blades bent over and made contact probably where it shouldn't have. The tech showed me the fuse that he said was the issue, it was marked as for something not even related to trailers or towing. It is Mopar so maybe? I agree the charge sounds crazy but to me, a child of the sixties, many charges are nuts. They charge $98.00 per hour for labor, they claimed they worked on for two to three hours. I sure appreciate all the knowledge coming from this group.
John
The earth without art is just eh....
crowwing is offline   Reply With Quote
Old 09-29-2016, 04:52 PM   #20
Plug not pug, locked not licked!
John
Old 09-29-2016, 06:17 PM   #21
Kai in Seattle's Avatar
Plug not pug, locked not licked! John
Typo, I meant locking the gates��--the park closed at dusk! LiseKen
Yes, of course a typo, and of course it was locked, not licked, I was fooling around. Struck me as funny. Too bad I missed the pug plug--we like pugs here, I'd have found that funny, too.
Not all typos are little gifts. Some are. These are.
The fuse: Sometimes these things take longer than they "should," and getting off for $98 isn't the worst that could have happened! 8)
Semper ubi sub ubi.
someone said looking for 25' Bigfoot trailer??? stude Referrals: Molded Fiberglass Trailers 10 08-06-2016 02:03 PM
Should I have said something? SRD General Chat 22 02-27-2014 02:09 PM
Owner said make an offer.... Cricket General Chat 24 10-04-2012 07:36 AM
Easier said than done Frederick L. Simson Modifications, Alterations and Updates 18 07-25-2007 11:54 PM
I've often said... Doug Mager General Chat 1 12-18-2006 08:36 AM
» Virginia Campgrounds
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
