wiring.....there, I said it. - Fiberglass RV
Old 09-28-2016, 08:24 AM   #1
Trailer: 2000 16ft Scamp
On my last excursion, as getting ready to leave the campground, the lights on my Scamp would not function except for a couple of side running lights. No blinkers, no brakes, no lights. After doing the usual adjustments, cleaner, fuse check etc. still no lights. I made the scary run home. I changed over the seven blade plug on the Scamp, still no lights. I gave up and took it to my local RV shop. My question is this, what should it cost to have all new wiring installed including the brake control? I want to be able to have some negotiating fire power when I pick it up. Appreciate the help, as always!
John
The earth without art is just eh....
crowwing is offline   Reply With Quote
Old 09-28-2016, 08:58 AM   #2
John
If they're telling you, you need all new wiring and brake controller run don't walk away and find another shop.
Old 09-28-2016, 09:12 AM   #3
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Make sure you have a good ground 1st.
Check tow vehicle to make sure all connections work.
Good luck.
Old 09-28-2016, 09:30 AM   #4
Trailer: 28' Bigfoot Silver Cloud
Oak Park, IL
Our Ford Expedition has both a 4 pin port and a 7 pin port for hooking up trailers. Our former trailer had a 4 pin port and I couldn't get the tail lights to work when plugged in. I tried it with an adapter in the 7 pin port and everything worked. So, I know the 4 pin port must be defective or have an issue on the tow vehicle. We sold that trailer and only use the 7 pin port now, but I know I need to troubleshoot the 4 pin port in future in case it's needed again. Tow vehicle ports do fail, too!
Old 09-28-2016, 09:41 AM   #5
Trailer: Hunter Compact Jr.
USA
For any electrical problem the first thing you should always do it check the ground. Then check it again, and then check it a third time.
Talia is offline   Reply With Quote
Old 09-28-2016, 10:17 AM   #6
I guess I should have been clearer in that if I pick up my jeep and they want to charge me $350.00, I would like to know what a whole new system would have cost installed.
John
Old 09-28-2016, 10:45 AM   #7
I'm not sure what you took to the RV center. The trailer or Jeep or both?
I would think if you have side marker lights and not Brake or running lights, especially running lights, you may have snagged the wires under the trailer. Side marker lights and running lights are the same circuit.
Phoneman is offline   Reply With Quote
Old 09-28-2016, 12:14 PM   #8
Trailer: trailswest campsterl, 1996 Scamp 16 foot
Idaho
Not directly related but a very good work around. We always have in the trailer a set of magnetized lights as used for cars in tow. Only takes a few minutes to rig them on your trailer. Nothing more frustrating than having to cancel a trip that is important and has been planned for some time. They don't solve the marker light issue ( which is irrelevant if you don't tow at night ) but they will give you turn indicators, stop lights etc. Then you can solve the real lighting issue when you return home. Lee
Lee Senn is offline   Reply With Quote
Old 09-28-2016, 12:36 PM   #9
Lee I like that idea. My last (and first) trip was delayed for hours once we were all packed and hitched up because of a loose wire in the 7 pin. Got it all reassembled but the troubleshooting caused the delay. Rolled into the campground at dusk, just as the ranger was licking the gate. Phew!
Lise in WA
LiseKen is offline   Reply With Quote
Old 09-28-2016, 01:50 PM   #10
Byron, I think what you asked was what you should expect to pay for a rewire. Has anyone told you that you require that much work? It may be quite simple to fix, as some here have suggested. Your place isn't necessarily out to fleece you. Our own RV place is pretty honest. The way they see it, they want to keep your business. And if you are suspicious, most garages are as capable at troubleshooting the kind of directional/running light problem you are talking about.
I worked in electronics for much of my life and so have little difficulty with this sort of thing. But if you lack experience, you can get a little gadget that fits on your car's trailer plug with LEDs that will allow you to check out the car wiring, just by plugging it in. And your automotive store will sell you a small LED tester that you can check for power with elsewhere. You may have to run a ground wire to it. If you don't have a wiring diagram of your trailer, there are universal ones online that are pretty close for the directional and running lights at least. Once your RV place has the lights working correctly, I'd suggest you do some checks yourself with your tools to discover how it tests when working right -for next time.
Randy J. is offline   Reply With Quote
Old 09-28-2016, 01:59 PM   #11
Kai in Seattle's Avatar
Wink
THAT would have been interesting to watch! Our rangers almost NEVER lick the gates while we're watching!
(Just kidding--understand your concern!)
Other question--Paul said perhaps a fuse was blown? Also, so far, no one knows how much it should cost? Neither do we. More than we'd like to pay, that's for sure. Feel for you!
Semper ubi sub ubi.
Old 09-28-2016, 04:27 PM   #12
Randy, I'm a retired Electronics Engineer and I know that many times a shop or garage will quote a lot more work than is necessary. They may quote the right amount for the work being done, but do a lot of unnecessary work.
If you're as knowledgeable as you claim it should be a simple matter to trouble shoot and fix what ever is causing the problem. But, do as you wish, it's your money.
Old 09-28-2016, 05:34 PM   #13
Problem fixed! They did a good job of scaring me with their estimates and 'might be'. It took them the entire day and found a blown fuse in the cabin of the jeep. They missed it on the first go through. Charged me $98.00, I think that is OK. Once again thanks for all your help. I will also watch for the MN park rangers licking the gates, maybe a video?
John
Old 09-28-2016, 08:50 PM   #14
Trailer: SCAMP
New Hampshire
John
A $98 to replace a fuse is incredible! That would have been the very first item and easiest to check! There was no sense checking anything after the no power point of the dead fuse! Don't go back there, an expensive lesson!
polskasila is offline   Reply With Quote
someone said looking for 25' Bigfoot trailer??? stude Referrals: Molded Fiberglass Trailers 10 08-06-2016 01:03 PM
Should I have said something? SRD General Chat 22 02-27-2014 01:09 PM
Owner said make an offer.... Cricket General Chat 24 10-04-2012 06:36 AM
Easier said than done Frederick L. Simson Modifications, Alterations and Updates 18 07-25-2007 10:54 PM
I've often said... Doug Mager General Chat 1 12-18-2006 07:36 AM
