Old 12-10-2009, 07:00 AM   #1
Trailer: 1985 U-Haul CT13 / 1990 Chevy S10 PU
In November I bought a 1985 U-Haul. Replaced a 25' Airstream which was getting too much to haul. Unit had been reworked as far as mechanicals, but cosmetics inside were rough. I thought some of my solutions to problems might be of interest.
Fiberglass surrounding cupboard inserts and icebox were in rough shape, cracked and weak. I cut lengths of 3/4 x 1 1/2" furring strips and screwed them to the back of the fiberglass to stiffen the glass. Then screwed liners and icebox thru glass to furring strips with sheet metal screws, using finish washers to get a better hold on the glass.
Stove had been pulled leaving a big ugly hole and glass counter was pretty well trashed. Since our only inside cooking will be on a microwave, I picked up some white-finished masonite used for wainscoting and cut a piece to fit the counter and cover the hole. attached it to counter with screws and finish washers and then added a splash panel of the same material. The splash panel covered the opening where the vent fan had been.
Previous owner had replaced the heater with a heat pump which took up a lot of closet. I made a panel of same masonite to conceal heat pump and then added two shelves above heat pump. The original closet door was cleaned up and closes the opening over the shelves.
We will not be using the dinette, so made it into permanent bed. Covered the whole dinette space with 1" styrofoam and 1/2" BC plywood. Then added original cushions and a layer of foam to make a cozy bed.
Lots of cleaning with English oil soap and our egg is about ready to travel. Looking forward to our first trip south in January.
PS: As I did this work, I found this Forum invaluable. Keep up the good work.
Eric Nelson is offline   Reply With Quote
Old 12-10-2009, 07:20 AM   #2
Sounds great Eric! Any pictures you could share? Let us know about your trips too.
Double Yolk
1988 16' Scamp Deluxe
Old 12-10-2009, 08:22 AM   #3
Donna
13 degrees out there today - will try to get pictures soon.
Eric
Old 12-10-2009, 11:12 AM   #4
Trailer: U-Haul CT13 ('Pearl')
SW Ohio
Hi Eric,
I have an Ohio Uhaul too! Be sure to put in that silver bubble insulation...it is a wonder. I used 4.5 rolls slid up between the layers of shell. I can get my Uhaul cosy with an electric heater in just a few minutes, even at 20 degrees! I'm looking into the options for the bed area. The foam intrigues me....Hmmm....that would really make it snug. I hope to get my front dinette finished and posted soon.....
Pat B Ohio is offline   Reply With Quote
Old 12-10-2009, 05:09 PM   #5
Hi Eric,
Pat
I wonder if we are the only U-Haul TT owners in Ohio. I'm not familiar with silver bubble insulation, and how do you slide it between layers. Sounds like a great idea. Little stinker cools off in a hurry when it gets cold.
Eric
Old 12-10-2009, 06:01 PM   #6
CindyL's Avatar
Trailer: 16 ft U-Haul VT
Illinois
You guys are not the only Ohio Uhaul owners. Uhaulcamper.com has one or two if they still participate since the web site was reorganized.
CindyL
CindyL is offline   Reply With Quote
Old 12-10-2009, 06:31 PM   #7
MikeCM's Avatar
Trailer: Actively shopping for a project, again.
Eric, Pat is referring to "reflectix" best described as bubble wrap between foil layers. The large home repair stores usually carry in either or both 24" or 48" rolls. Reflectix Inc. In the past few days I read somewhere on this site about air space adding to the insulating rating (perhaps it was Raya L. that posted the link).
We started using reflectix with our first popup under the mattress to limit the condensation and keeping the bed warmer.
Mike
Former 83 Burro Owner (destroyed in fire)
Looking for a new Fiberglass Project Trailer in New England.
Currently camping in our 84 Cobra Class C
MikeCM is offline   Reply With Quote
Old 12-10-2009, 07:10 PM   #8
SW Ohio
I'm glad Mike is here to get my terms right. It's just the silver bubble stuff to me. I got the 16" rolls at Menards...then you slip it between the layers and use friction with a bit of tape to hold it in place. It's 13 degrees and a small electric heater warms it up even with the wind. The only drawback is be prepared to get spiked by fiberglass shreds. I got it behind most double wall areas. You must be careful of the wiring. It was well worth it. When I redo the head liner, I will install it under the carpet.
Old 12-12-2009, 01:42 PM   #9
Trailer: Casita 17 ft Spirit Deluxe 2007
You Ohio Uhaulers really need to make it to next year's gathering at Caesar's Creek State Park. There are a lot of Casitas but other fiberglass is fun to see.
Terry R. is offline   Reply With Quote
Old 12-12-2009, 07:38 PM   #10
Trailer: U-Haul 16 ft Vacationer (VT)
Oak Park, IL
We try to go to the Shawnee pow-wow at Zane Caverns each year in August. Where in west central Ohio do you live? (Zane Caverns is near Bellefontaine.)
Old 12-13-2009, 06:16 AM   #11
Steve DeWeese's Avatar
Trailer: 1978 Trillium 13 ft
I know I don't post much, but I am here as well. My friend bought a 13ft U-Haul and did not like it, I don't understand what is not to like. Since I found it for him I felt the need to buy it from him. It now sits in Tiffin OH at my fathers house. I promised it to my daughter but am beginning to believe she is never going to come and get it. I also have a 13ft Trillium which I love even though it still is not fixed up since I bought it. I live in Dayton OH and am still in the AF but may be forced (because I don't want to go) to retire soon. I may find myself with extra time to fix up both of these trailers and no I don't want to sell either no matter what just encase someone might ask. I hope to get more involved in going to more meets if the worse happens.
Steve DeWeese is offline   Reply With Quote
Old 12-13-2009, 06:20 AM   #12
Celina
Old 12-13-2009, 06:27 AM   #13
These little porta-pottys on wheels (my daughters comment) are the only trailers I've seen that are larger inside than outside. When I'm working on ours sometimes I just sit for awhile on the couch, look around and think, "Wow, this is really neat." I'm really looking forward to getting ours on the road.
Eric
Old 12-13-2009, 12:51 PM   #14
David and Theresa Shibley's Avatar
Name: David & Theresa
Trailer: 13 ft Burro
Hello Everyone
Well I'm sitting here in my office looking out the back at our 13' Burro burried in snow. I can't wait until spring.
Anyway Pat and Mike I was wondering if you had used single or double sided Reflextix and how is the condensation if any?
David and Theresa Snow Belt Ontario
David and Theresa Shibley is offline   Reply With Quote
u-haul
U-haul 13ct Marty D Care and Feeding of Molded Fiberglass Trailers 48 06-29-2011 09:07 AM
1985 13 ft U-Haul camper on ebay harold w Classified Archives 7 08-01-2009 06:42 AM
1985 13' U-Haul For Sale - near mint harold w Classified Archives 7 07-10-2009 05:52 AM
1985 U-Haul Terry R. Classified Archives 10 04-04-2009 08:48 PM
SOLD - 1985 13' U-Haul For Sale CharlieD Classified Archives 7 03-11-2009 03:01 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
