Yet another rivet question - Page 4 - Fiberglass RV
Old 08-09-2016, 01:07 PM   #43
Trailer: 2010 Casita 17 Spirit Deluxe
Wisconsin
Originally Posted by Darral T. View Post
So the crooked rivet in the photo I think may have happened because it worked loose then allowed the closet to shift around while on the road- bumps etc. and caused this.
The hole above the fridge on my Casita was drilled by a politician, it appears to be crooked from the factory.
Vtec is offline   Reply With Quote
Old 08-10-2016, 08:30 AM   #44
Wisconsin
Good news! After posting this thread I went out and got a rivet to stick in that spot. Before pulling the rivet I bummed firmly on the rivet gun a few times to get it good and tight and it had a good comfortable amount sticking out. My son held the acorn nut tight as well. I will get around to replacing all of those over the fridge and firm them up as it will surely happen again if the others are a little loose.
I was actually fully prepared to replace it with a 10-24 flat head machine screw, a neoprene washer up on top for angle cushion, a 5 mm lock washer, and an acorn nut that was not much smaller than a 1/4-20. I will keep that hardware around for backup or the give up if it keeps falling out.
Old 08-10-2016, 08:32 PM   #45
Trailer: '09 Scamp 13' w/ Bath
Vtec,
Glad you had success! Hopefully I will have the same when I get around to doing some rivet work.
fieldphoto is offline   Reply With Quote
Yet another vent re-seal question: compact Junior Kent I Problem Solving | Owners Helping Owners 10 06-15-2009 04:18 PM
Yet another generator question Vi Turner Problem Solving | Owners Helping Owners 6 06-13-2009 07:13 PM
And yet another axle question?? Don N Towing, Hitching, Axles and Running Gear 19 01-11-2009 10:32 AM
Yet another propane question... Todd Sleeman Problem Solving | Owners Helping Owners 7 06-23-2008 04:33 PM
Yet another towing question Greg Yother General Chat 16 04-11-2007 05:09 PM
