1/2" Grade 8 bolt question. - Fiberglass RV
Old 04-13-2008, 02:18 PM   #1
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Is a 1/2' Grade 8 bolt, strong enough to bolt a dexter axle bracket to a 13' Scamp trailer?
Old 04-13-2008, 03:20 PM   #2
Pete Dumbleton's Avatar
It might be too 'strong'. As the hardness and grade go up, so does the brittleness (you wouldn't want a very hard diamond bolt in there, would you?). Most receiver hitch manf supply and specify Grade 5 bolts. Dexter does spec the torque for your kit's 1/2" at 70-90 ft-lbs.
http://dexteraxle.com/i/u/1080235/f/6-8K%2...0-05_80_res.pdf
It might be a moot point, however, as I think the correct hardware comes with the A/P -165 hanger kit. You could call Dexter to be sure about that. Give us some feedback.
Old 04-13-2008, 03:45 PM   #3
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Looks like grade 8 -------Dexter axle says 70-90 ft lbs grade 8 = 92 ft lbs grade 5 = 60 ft lbs
http://www.angelfire.com/fl4/pontiacdude428/Bolt.html
Old 04-13-2008, 04:49 PM   #4
Table says those are minimum torques, so the either is still possible, but I would lean towards the G-5, because Dexter's 70-90 is slightly below Table minimum of 92 for G-8.
Good table; I didn't know that socket head cap screws are even harder than G-8 and the reduction factors for lubes is useful.
Old 04-13-2008, 09:34 PM   #5
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Pete Dumbleton
Good point,I think I will go with the Grade 5 Bolts.
Old 04-13-2008, 10:19 PM   #6
Just go with whatever Dexter puts in the bracket kit!
Old 04-16-2008, 07:03 PM   #7
Trailer: Casita 16 ft / Jeep Cherokee
Grade 8 is fine, not too brittle.
Before they went metric, you'd see grade 8 bolts all over CAT equipment.
(now they're usually metric 10.9 grade)
Bill Murray is offline   Reply With Quote
Another "wall paper" question Vicki A. Care and Feeding of Molded Fiberglass Trailers 7 03-10-2010 12:13 AM
Question for Scamp 5th wheel owners: 14" Tires? peterh Towing, Hitching, Axles and Running Gear 5 10-17-2008 10:21 PM
Major Server Up Grade Today Bigfoot Mike General Chat 4 08-14-2007 04:51 PM
Server Up Grade Bigfoot Mike General Chat 15 06-28-2007 11:31 AM
Can you pass the third grade? Benita Jokes, Stories & Tall Tales 22 03-31-2007 01:03 PM
