12 Volt drain - Fiberglass RV
Old 06-05-2006, 04:43 AM   #1
Lyndon Laney's Avatar
Trailer: 1996 19 ft Scamp 19 ft 5th Wheel ('TOGETHERNEST' SLEEPS 8
Just a note to remind everyone .if you are losing 12 volt power . be sure to unplug your 12 volt TV. most of them have a memory saver that draws power when the set is off and will depleat a betery in a few days.
Lyndon Laney is offline   Reply With Quote
Old 06-05-2006, 07:39 AM   #2
Gina D.'s Avatar
and...
how do you know this?
Old 06-06-2006, 04:57 AM   #3
and...
Several ways Gina.
1 just leave your trailer set with TV plugged in for a week and you wiill find the Batery down considerable.
2 with everything pluged in disconect either conection on the Batery and try a 12 volt test light from the batery post to the wire you removed, the light shouldn't light. if it does unplug the TV. Or pull fuses until the light goes out Your culprit will be on that circuit
3 Or maybe the TV manual.
Two 6 volt vs. 12 volt deep cycle Kevin242 Electrical | Charging, Systems, Solar and Generators 15 05-13-2017 09:52 AM
Battery Drain Donna & Chris Problem Solving | Owners Helping Owners 8 08-02-2008 09:15 PM
Battery drain Legacy Posts Care and Feeding of Molded Fiberglass Trailers 25 04-04-2003 08:14 AM
shower drain Legacy Posts Problem Solving | Owners Helping Owners 8 10-02-2002 06:28 PM
Where does the refer drain? General Chat 0 01-01-1970 12:00 AM
» Trailer Showcase
Scamp
chefjj
Hunter
Gmakt
