12 volt LED bulbs - Fiberglass RV
Old 06-05-2016, 06:47 PM   #1
Trailer: 2008 OutBack 13ft., Camp Inn 560
Illinois
12 volt LED bulbs
Can any body tell me why these 12 volt LED bulbs could not be used in an RV with a converter?
I have never seen that disclaimer before.
Not for RV/Trailer use when used with converter. RV power fluctuations can damage a regular LED light.
6 x EBA LED 12V115613 LED Replacement Bulb
1141/1156 Base Tower 12V DC 13 LED Natural White
Description:
  • 1156/1141 base bulb
  • Applications include 12 Volt DC only. Auto, marine, RV and military vehicles. Not for RV/Trailer use when used with converter. RV power fluctuations can damage a regular LED light.
  • Color temp: 4000-4500K Natural White
David O. is offline   Reply With Quote
Old 06-05-2016, 06:57 PM   #2
Trailer: 94 Scamp 13 ft
Following....
Sheryl M is offline   Reply With Quote
Old 06-05-2016, 07:29 PM   #3
No doubt because the are cheaply made (no regulator) and not tolerant of the higher voltage a converter will sometimes put out (like when charging the battery or going into equalization mode, if it has that mode).
Originally Posted by Sheryl M View Post
Following....
For future reference, you can just subscribe to the thread to follow it. Click on Thread Tools.. then subscribe.
Old 06-05-2016, 07:29 PM   #4
rdickens's Avatar
Trailer: 2017 Scamp 16 Deluxe
When our converter is plugged into 110v "shore power", the voltage at our 12v DC plug usually reads 13.6v. When nearby air conditioners cycle on and off, I suspect that there is a spike in the AC voltage that translates into a corresponding spike in the DC voltage.
If I am remembering correctly, if an LED bulb is not designed to handle fluctuations in voltage, some of the light emitting SMDs can burn out or start to flicker on and off.
I have had to replace a number of cheaper LEDs because they were flickering.
Perhaps someone else may have a better explanation.
And, of course, .......... YMMV! 😉
Good luck! 😊
Ray
rdickens is offline   Reply With Quote
Old 06-05-2016, 07:33 PM   #5
Illinois
Thank you.
Old 06-05-2016, 08:58 PM   #6
I recently purchased 4 very bright 12 volt LED bulbs dirt cheap on ebay - $6 shipped for all four (shipped from the USA - arrived in a few days). It was a 5 minute job to swap out the outside, bathroom and table light bulbs. I don't know if they will last but they put out plenty of low energy light! For six bucks, why not? 4X Cool White 1156 BA15S 50 SMD Car RV LED Turn Signal Light Bulb 1141 1073 1003 | eBay
Lake_Mich_Scamp is offline   Reply With Quote
Old 06-05-2016, 09:49 PM   #7
Triker's Avatar
Trailer: 2016 Scamp 13'
Hi Hugh,
Great buy! Just in case, you might want to watch for any heat build up. I've found some of the bulbs with a large amount of LEDs to put out too much heat. A couple even warmed up the double-backed foam tape to where it curled. I've gotten them from USA and direct from China, and all the ones I got performed the same way. So I'm trying out some 24-SMD ones now, and so far so good.
Triker is offline   Reply With Quote
Old 06-06-2016, 09:34 AM   #8
Kai in Seattle's Avatar
THANKS! We've been looking for quite a while, Paul wanted these very much so we bought 8. Coming from Washington, so shouldn't be much of a wait (they said Saturday). Will post if they don't work out.
Semper ubi sub ubi.
Old 06-06-2016, 02:37 PM   #9
Larry C Hanson's Avatar
Old Converters
Interesting.
Might be cause some older original converters had
no voltage regulation. The original converter in my
'78 Trillium measured over 19VDC at the outlets
with no load applied.... Probably would fry LED
bulbs. The WFCO WF-8725 I installed in the trailer
many years ago has not affected the life of the
inexpensive LED bulbs I bought on Ebay.
Good Luck
Larry H
how to find working LED bulbs? LukeP Electrical | Charging, Systems, Solar and Generators 21 07-15-2012 07:29 PM
LED bulbs Perry Mac Donald General Chat 6 01-27-2010 02:51 PM
Bulbs Replaced With LED's in Escape - Fantastic! dkdavies Modifications, Alterations and Updates 9 05-31-2008 11:28 PM
LED light bulbs for Scamp ted saxton Modifications, Alterations and Updates 0 09-18-2007 04:35 AM
LED taillight bulbs Alistair Camelford General Chat 9 11-10-2006 01:39 PM
