You might check out the Wikipedia Cigarette lighter receptacle page, which explains that there are two slightly different sizes (I assume you would want the slightly bigger of the two). There's also a somwhat common socket which is significantly smaller, and frequently associated with BMW, defined by the ISO 4165 standard... you presumably don't want that in a trailer here.
