12 volt outlets - Fiberglass RV
Old 08-02-2016, 11:11 AM   #1
12 volt outlets
Neither of the 12 volt outlets on my new scamp work. I was assuming I could use this to charge my cell phone etc is that wrong? Is there a switch for them somewhere? I've called scamp a couple times and left messages but they haven't gotten back to me yet. The trailer is still under warranty but if I'm doing something wrong and just being stupid I guess I'd like to start there. Thanks for the help!
gtaylor is offline   Reply With Quote
Old 08-02-2016, 12:04 PM   #2
Have you checked the fuse in the power panel? Do any of your other 12 volt items work? Are you running 120 volts and converting to 12 volts or are you running only on your battery? If your running on 120 volts make sure everything in your power panel is turned on.
Old 08-02-2016, 12:08 PM   #3
Trailer: U Hall VT
Do you have a switch to go from 120 to 12V?
Roger Kimble is offline   Reply With Quote
Old 08-03-2016, 09:48 AM   #4
You say your trailer is still under warranty, so it is a 2015 or 2016? If so, the lights are 12 volts. Do they work? If so, most likely culprit is a bad fuse for the 12 volt outlets. If you don't already have one, get a cheap multimeter so you can check voltages on your rig. Also, do as stevebaz suggests; make sure the main breaker and the one for the converter are turned on. If all that fails, lift up the port side seat hatch and check that no wires have come adrift from the terminal board you will see there. The 12 volt circuits are those towards the front of the board.
ravensrest is offline   Reply With Quote
Old 08-03-2016, 10:01 AM   #5
Originally Posted by ravensrest View Post
...If all that fails, lift up the port side seat hatch and check that no wires have come adrift from the terminal board you will see there. The 12 volt circuits are those towards the front of the board.
Don't know about the OP's rig, but in a 2015 Scamp 16 there is no terminal board in the port side hatch (under the seat)... there is a converter, but the power distribution panel is separate and in the port side cabinet below where the standard fridge would be if I had one.. so don't be confused if your set up is different.
By this time you should have talked to Scamp so they can guide you as to where the wiring for the outlets is, what color wires, where the fuse(s) are, etc. for your rig.
Old 08-03-2016, 10:08 AM   #6
Yes, you can charge your phone from "working" 12v outlets in the Scamp.
As some mention in a different way, you NEED to be able to "troubleshoot" with some very simple tests.
First, did you get the onboard battery? It would be sitting up front on the tongue...or at least my 2010 does. If not, then you wont have 12v unless you're hooked up to your tow vehicle or plugged into shore power (120v pedestal). IF you have the battery, is it charged? You could check this with a simple volt meter. Your onboard battery also has an inline "fuse". Mine is located in the front closet next to the bathroom. Is the fuse good?
Second and somebody's suggested it already... does any of your smaller 12v lights work? The reason I say "smaller", they included a 16-18" fluorescent light over my sink that is 120v only.
The answers to the questions above could take us to the next troubleshooting area.
Old 08-03-2016, 02:53 PM   #7
M Scott's Avatar
Trailer: 13 ft 2005 Scamp Deluxe; 2002 Subaru V6 Outback
I'm not sure if I have 12 volt outlets in my 2005 Scamp (bought second-hand). So I bought a Viatek Pocket Jump (emergency vehicle jump starter & portable power pack); fits easily in my vehicle glove box, and will also charge all my portable devices. I don't expect it to work on a poor battery, though.
M Scott is offline   Reply With Quote
Old 08-03-2016, 03:44 PM   #8
Usually, Scamp install's one 12v as standard. I had an extra installed on the bulkhead and it's accessible as you come through the door. I use one of the voltage meters that plug in. It saved me one time as I was plugged into shore power showing less than the standard 13.6 volts that the converter puts out. I found my converter had come unplugged inside the water heater/electrical box compartment.
Old 08-03-2016, 04:08 PM   #9
Originally Posted by Darral T. View Post
Usually, Scamp install's one 12v as standard....
Not that it really matters but I am quite sure than even the first 12 VDC outlet is an option only ($30 at last check).
I added two 12 VDC outlets and one two port USB outlet myself because I did not like the location where Scamp puts them.
Old 08-03-2016, 04:11 PM   #10
Raz
Raz's Avatar
Vermont
I'm not sure if I have 12 volt outlets in my 2005 Scamp (bought second-hand). .
The socket that used to be used for a cigarette lighter has been adopted as a 12 volt socket. Most vehicles have at least one. Look around yours and you'll see what they look like. Some times they have a flip up cover. I bet there is one somewhere in your Scamp but maybe not.. My Trillium didn't have any. . Raz
Old 08-03-2016, 06:38 PM   #11
M Scott's Avatar
According to Scamp 2005 brochure, the 12 volt plug is an option, even on the deluxe. I assume any installation at the plant would be in the same location on the trailer. Does anyone know where I should look?
Old 08-03-2016, 07:30 PM   #12
Yes that is the way I read the brochures also...
I think that the standard install is on on the side of the cabinet by the dinette / bed, near the 120 volt outlets and water pump switch (which I also relocated by the way).
I also believe they use the outlets without covers.
If there is not one in plain sight, than I doubt you have one.
If you want one, however, its not hard.
Old 08-03-2016, 07:53 PM   #13
Sometimes the 12V plug is on the same outlet/connection as the TV Cable connection if you have one.
Old 08-03-2016, 08:13 PM   #14
M Scott's Avatar
Thanks, Gordon. No outlet found, so guess I'll stick to my Viatek Pocket Jump which might also be good on kayak trips.
Two 6 volt vs. 12 volt deep cycle kevin242 Electrical | Charging, Systems, Solar and Generators 15 05-13-2017 09:52 AM
Engel MR40F 12 Volt Refrigerator 12 Volt Freezer Mike-N-Laurie Misc: Buy | Sell | Trade 1 04-26-2016 08:05 AM
Mobicool propane, 12 volt, 120 volt cooler Nelmes Parts: Buy | Sell | Trade 0 06-10-2014 01:36 PM
110 volt and 12 volt on the same switch? Chris Jones Modifications, Alterations and Updates 46 04-04-2013 01:36 PM
110 Outlets In a 16' Spirit Deluxe Legacy Posts Problem Solving | Owners Helping Owners 11 11-05-2002 05:04 PM
