12 volt question - Fiberglass RV
Old 05-08-2012, 05:54 PM   #1
Dave M's Avatar
Trailer: 72 Boler American
12 volt question
I have some 12 volt lights and a Fantastic fan in my 1972 Boler 13. They were hooked up to a 12 volt car battery that I just recycled. My battery charger went belly up also. We are always on 120 ac so I'd love to power the 12's that way. So what are some options here?
Dave M is offline   Reply With Quote
Old 05-08-2012, 05:59 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
You need a power converter - 120 volts AC to 12 volts DC. Any RV place sells 'em.
Old 05-08-2012, 06:16 PM   #3
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
Or, if you don't ever expect to get a battery & the only thing you want to power is the fan, a less expensive solution would be a 120V to 12V power supply. It needs to provide enough current for the fan - if you give them a call at 800-521-0298 with your model number they can tell you what the maximum current would be. I believe they also sell a 120 to 12 volt converter made for their fans...
If you are also going to power lights (particularly incandescent) than the RV converter is probably the beat way to go.
Old 05-08-2012, 06:26 PM   #4
Trailer: Burro
Power Converter
I got a power converter of off ebay for around $100, it is a WF-8935
35 amp. so far so good it works good, I have my interior lights, over the range fan and roof fan and can work them all at the same time.
AJ
megatrack is offline   Reply With Quote
Old 05-08-2012, 08:10 PM   #5
Dave M's Avatar
I've seen those before and wondered if they would work. Would one of these do the trick? How many amps?
Old 05-09-2012, 05:35 AM   #6
Trailer: Trillium 4500 1977
Quebec
Definitely ! You will appreciate the automatic variable fan speed at night, it is quieter. The amount of amps depends on the the accessories you want to use, considering the limited battery power.
I think the 30A version is enough for a very small RV. If you are planning to hook on 120V for extended periods, the battery wizard option would prevent your battery from overcharging.
Martin J. Qc Canada
lamimartin is offline   Reply With Quote
Old 05-09-2012, 09:34 PM   #7
Trailer: Burro
This would work but you do need a distribution panel to distribute the power to different circuit.
Salut Quebec!
AJ
Old 05-10-2012, 11:24 AM   #8
Dave M's Avatar
Is a distribution panel necessary for 3 lights and a vent fan?
Old 05-10-2012, 11:27 AM   #9
NO it's not.
But the lights and fan should be fused separately. In-line fuses will work just fine.
Old 05-10-2012, 07:33 PM   #10
Trailer: Burro
I personnaly would not go without a distribution panel, It's More organized and if you decide to add a circuit it's easy, But Byron is right, you can hardwire it with an inline fuse.
Two 6 volt vs. 12 volt deep cycle kevin242 Electrical | Charging, Systems, Solar and Generators 15 05-13-2017 09:52 AM
12 volt transformer Rick kl Problem Solving | Owners Helping Owners 2 10-07-2008 11:24 AM
12 volt outlet RonMayo Modifications, Alterations and Updates 9 08-21-2008 06:45 PM
12 Volt Legacy Posts Problem Solving | Owners Helping Owners 20 07-03-2003 02:43 PM
12 volt Legacy Posts Electrical | Charging, Systems, Solar and Generators 31 05-23-2003 06:46 AM
