12 volt system - Page 3 - Fiberglass RV
Old 12-20-2017, 09:59 AM   #41
Trailer: Escape 15A
My (recently purchased) U-haul has an AGM battery mainly to power the vent fan, lights are all individually powered LEDs. There is not charging system at the moment, but I would like to install something. Can I rig the battery to charge off of the vehicle when connected via a 4-pin harness, or would I have to change to a 7-pin harness?
Steve Carlson is offline   Reply With Quote
Old 12-20-2017, 11:06 AM   #42
ZachO's Avatar
Trailer: Sasquatch
Montana
You could rig it. At that point it might be just as easy (and cleaner) to install the 7-pin, though.
Old 12-20-2017, 11:44 AM   #43
Trailer: Escape 15A
Yeah. I'm leaning toward keeping the 4-pin and running a separate power wire for battery charging. Our other trailers are all set up with 4-pin connectors.
Rigging power would also give me the option of keeping the 12V fridge in the camper instead of the vehicle while on the road.
Old 12-20-2017, 11:56 AM   #44
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
Be careful putting your fridge in the trailer. Make sure it is firmly secured so it won't bounce around too much.
Also, make sure the charge connection to your TV is only active when the vehicle is running so you won't drain the TV battery when stopped. Some other members learned the hard way that even getting it installed by professionals doesn't guarantee that.
Old 12-20-2017, 12:25 PM   #45
ZachO's Avatar
Trailer: Sasquatch
Montana
Yep, do what works!
FWIW, many 7-pin connectors are also wired with a 4-pin connector, so you can connect both types. Mine is that way.
Old 12-20-2017, 03:24 PM   #46
Trailer: Trail Cruiser
Either way would work
Old 12-21-2017, 12:17 AM   #47
Borrego Dave's Avatar
Wire it up the way it makes it easier and works best for you Steve. I wired up the flat four, round 6 pin & the 7 on my truck so I don't have to use adapters with any of my trailer herd .
Old 12-27-2017, 07:58 AM   #48
Lydia W's Avatar
Trailer: 75 Scamp 13 ft
I had my 1975 13' Scamp wired for solar and had a battery installed this past summer. The battery is housed under the dinette seat (on the drivers side) and is vented to the outside. So far no problems!
Lydia W is offline   Reply With Quote
Two 6 volt vs. 12 volt deep cycle Kevin242 Electrical | Charging, Systems, Solar and Generators 15 05-13-2017 09:52 AM
Engel MR40F 12 Volt Refrigerator 12 Volt Freezer Mike-N-Laurie Classified Archives 1 04-26-2016 08:05 AM
110 volt and 12 volt on the same switch? Chris Jones Modifications, Alterations and Updates 46 04-04-2013 01:36 PM
Help adding a 12 volt system to a scamp 13 UncleJosh Electrical | Charging, Systems, Solar and Generators 10 03-31-2006 09:30 PM
