12v lights not working - Fiberglass RV
Old 09-12-2010, 11:09 PM   #1
Trailer: 74 Boler
I just got back from a weekend camping with the family and tried to turn on one of the 12v lights and it didn't work. They had been working all weekend so I figured a light had been left on and the battery was dead so I hooked up the charger and still nothing. So I started looking at the battery connections etc and everything was good. there is two switches on the side of my fridge, one for 12v and one for 110, when I bought the trailer the guy said make sure they aren't both on because you'll fry the fridge. I noticed that some thing had shifted on the way home and switched them both on, the fridge seems to work fine on 110 but the lights still don't work. All of this to say is there a fuse or fuseable link somewhere from the factory? I'm ok with tracing wiring, I used to do car audio and alarm installs for a living, but it would be nice to have a little guidance on a possible location
Thanks!
Brian Tin is offline   Reply With Quote
Old 09-13-2010, 07:23 AM   #2
Roy in TO's Avatar
Every fridge I've seen has an interconnect to prevent both 110 and 12V from being on at the same time. Figure out what model fridge you have and check the Document Center on the Left Side Bar here to find a service manual.
If you can't find your fridge, post the model and someone usually will pipe in.
Most bolers had an inline fuse under the front bunk forward of the fridge.
Old 09-13-2010, 12:19 PM   #3
Trailer: 74 Boler
Cool, I will check that out
Thanks!
Old 09-13-2010, 05:34 PM   #4
Trailer: 74 Boler
Looks like it was a false alarm. I hooked up the multi meter to the battery where I had my friends brand new battery charger hooked up over night and it showed 2.3 volts, that seemed odd so I hooked up a charger that is older than the hills and it shows 12.2 volts. It ends up my friends charger is a "smart charger" and it won't charge anything under 3 volts, that doesn't seem to "smart" to me, it won't charge a dead battery like an old guy once told me "they don't make them like they used to"
Old 09-13-2010, 10:42 PM   #5
Roy in TO's Avatar
OK then, run some stuff off battery for a while to drop the voltage down a bit to about 11V. Then hook up the smart charger.
lighting, lights
3way fridge not working on 12V Rick G Problem Solving | Owners Helping Owners 28 03-31-2010 10:44 AM
Running lights not working DavidS Problem Solving | Owners Helping Owners 2 09-06-2009 10:15 AM
Bigfoot trailer backup lights not working MountainHome Problem Solving | Owners Helping Owners 5 04-26-2008 10:37 PM
DC lights working with no battery connected???? dora D Problem Solving | Owners Helping Owners 4 10-10-2007 06:17 PM
Reading lights-looking for 12V (non-halogen)-maybe LED'S? JenW Problem Solving | Owners Helping Owners 30 09-21-2007 10:38 AM
