13' Boler Frame Size - Fiberglass RV
Old 03-01-2011, 10:29 AM   #1
lespnd's Avatar
Trailer: 1300 Boler -The Pine Cone
I am replacing my 1972 Boler C channel frame with a closed channel from 1978 (which I have yet to pickup). Are there any differences between the two frames in terms of how the carriage fits, other than the axels/brakes?
lespnd is offline   Reply With Quote
Old 03-02-2011, 07:11 PM   #2
james kent's Avatar
Trailer: Boler 1984
I am not familiar with the 72 frame. I do realize that some earlier bolers had a flat floor verses the later step floor. If this is the case then you may run into dificulties. Bolers and frames from the different manufacturers over the years may also be slightly different but you could probably shim and trim to fit.
Old 03-03-2011, 10:00 AM   #3
lespnd's Avatar
Hi James, Mine has the step for the front and step in the back where the table is. I have an opportunity to buy a frame that has brakes. I'm just curious about the dimensions as I'm hoping boler didn't change the dimensions of their shells. However, Even it was slightly different, I could modify it to fit no problem. Thanks for your input.
Old 03-03-2011, 08:31 PM   #4
Greg H's Avatar
Trailer: 72 Boler American
Indiana
My '72 Boler American has a boxed frame, not a C channel, I would imagine that they are the same.
boler
Removing frame from 13' boler...one question... thenoob Problem Solving | Owners Helping Owners 11 10-08-2010 07:09 PM
Boler #2 frame off RogerH Modifications, Alterations and Updates 18 04-28-2010 06:05 PM
Another boler frame off... RogerH Modifications, Alterations and Updates 21 06-18-2009 06:38 AM
New Frame for a Boler Cheryl Lee Problem Solving | Owners Helping Owners 2 01-28-2008 09:13 AM
Boler Frame RobJ Modifications, Alterations and Updates 6 03-19-2007 03:16 PM
