13' burro remodel with pictures - Page 2 - Fiberglass RV
Old 05-30-2013, 09:59 AM   #15
Trailer: Scamp 13 & TDI tugboat
Ohio
Linda, the instruction manual for the Dometic 211 fridge can be downloaded from this page:
Fiberglass RV - Document Center - Refrigerators
Print it out and keep it in the camper, along with any other "how do it work" info for things like furnace, inverter/charger, etc.
FJ40Jim is offline   Reply With Quote
Old 06-03-2013, 08:52 PM   #16
Trailer: Burro 13'
I removed all the gas fixtures and lines. I am staying away from gas and opting to put in a 12v system that will be independent of the 110v service. I will cook with gas outside and will be using a cooler in place of the fridge. Will be keeping the sink and hooking it up to 12v pump to small 3 or 5 gallon tank.
As far as your floor, I do not have any better way for you to look for the way the table mounted other then ripping up the carpet.
ADK burro bret is offline   Reply With Quote
Old 09-10-2013, 06:02 PM   #17
Trailer: Burro 13'. 1982
Montana
Just wondering........did you keep the table? Or is the bed "permanent"? If it is, where do you eat? Outside?
Lfoxmont is offline   Reply With Quote
Old 09-10-2013, 06:05 PM   #18
Montana
Originally Posted by ADK burro bret View Post
Day 1:
- Removed Shell from trailer and set on blocks.
- Gutted interior of refrigerator, water tank... basically everything...
- Started the process of removing rotten floor (need advise on cutting the floor away from external fiberglass shell as the floor and walls are joined with fiberglass, i am thinking grinder or dremmel). The interior shell was just screwed down to the floor and not fiberglassed in place.
- Removed front and rear windows ( I am planning on running long planks from front to back through the window openings to support the shell so i will not need to support the shell from the bottom. This way i can completely remove the old floor).
I am also looking for suggestions for the new floor. I assume i will need to install the floor in 2 or more sections due to the lip on the exterior shell that the wood needs to slide into. I am looking for advise on materials, how they installed the floor in sections, and how they joined them together keeping the sections from sagging.
I look forward to reading suggestions.
End of day one... Day 2 should be fun...
Iphone pictures uploaded upside down... sorry for the head tilt...
Sorry....my question about the table was for you......
burro
Burro 13 remodel Faye J. Modifications, Alterations and Updates 7 03-21-2012 07:21 PM
Remodel vs Original Donna Adams Care and Feeding of Molded Fiberglass Trailers 9 11-02-2009 10:03 PM
Burro 13 pictures (please share) JeremyHammons Modifications, Alterations and Updates 9 03-17-2009 10:00 AM
Burro Project Pictures Randy Bishop Problem Solving | Owners Helping Owners 2 05-02-2007 11:15 AM
Pictures of our Burro Christi W General Chat 1 02-08-2007 08:07 PM
