13' Burro roof - Fiberglass RV
Old 02-24-2003, 04:23 PM   #1
13' Burro roof
While looking out the window longingly ( as I do often) at my beloved Burro. My eyes once again are drawn to the dip in the roof right where the vent is placed. Now, it doesn't leak and it seems solid enough. I think it may have been that way from day 1.
But it does bug me to see it. Especially after seeing all the perfect roofs in the photos on this site.
Of course if I was in it camping, I wouldn't notice it until I washed and waxed it again. That area does pool water, so I have to sponge it dry before I can wax it.
Any ideas?
Or should I just start looking out the basement window instead?
Old 02-24-2003, 04:29 PM   #2
Burro vent dip
Should be interesting to hear from other Burro owners about this situation. Reading your description - I found myself wondering if it might be a result of Burro's double-hull construction. I suppose if there is an airspace between the two at that point - the vent could pull down the upper roof if it was clamped too thin (ie if the outer part and the inner trim didn't have sufficient space between them). If that WERE the cause - I'd think the vent could be removed, the area around the vent opening shimmed up to eliminate the sag and the vent reinstalled through the shims.
Just a thought...
mkw
Old 02-24-2003, 04:53 PM   #3
It's a good thought Mike. The original paperwork shows its had a power vent, but it doesn't now. It could be that's what happened when it was replaced.
I was thinking about putting a power vent in later this year maybe. That will be a good time to test your theory.
burro
Burro Roof Sag Jill C Problem Solving | Owners Helping Owners 12 11-08-2009 09:57 PM
NEED replacement roof vent for 13ft Burro? davidbelitz Care and Feeding of Molded Fiberglass Trailers 3 10-10-2009 08:35 PM
Burro Roof Vent David and Theresa Shibley Problem Solving | Owners Helping Owners 2 07-29-2009 06:22 PM
Burro roof a/c Mike Ethridge Modifications, Alterations and Updates 10 06-04-2007 08:15 AM
Burro roof a/c placement Christi W Problem Solving | Owners Helping Owners 17 02-07-2007 12:43 AM
