Steve the
Boler hinges themselves are not a direct replacement with the
Scamp hinge, but some have had success using them.
Pair Of Outside Door Hinges. Be aware
Scamp calls a pair both sides of one hinge... so you'd need to order two pair! The
Scamp hinge is a three bolt vs the two bolt
Boler. So, if the
Boler hinge is in good shape, the guts for pivoting are replaceable:
Door Hinge Repair Kit (Brass Ball, Spring, Nut & Bolt). I've read on Bolerama that it's suggested to replace the bolt with one made of stainless steel.
Now I gotta go look at your pics!
