13 ft boler door hinges - Fiberglass RV
Old 09-11-2009, 08:20 PM   #1
Trailer: Boler 1300
I removed the door as it was sagging, so needs a hinge repair job, but it seems the sockets that the balls sit in are worn, and I cannot remove the hinges from the body. if I have to I will grind a slot into them and try a slotted driver, but thought I would ask here 1st.
also where can I get a replacement set. in the vancouver / lower mainland bc area. or are there any mods out there.
thanks
Steve
steve J is offline   Reply With Quote
Old 09-11-2009, 09:01 PM   #2
Steve the Boler hinges themselves are not a direct replacement with the Scamp hinge, but some have had success using them. Pair Of Outside Door Hinges. Be aware Scamp calls a pair both sides of one hinge... so you'd need to order two pair! The Scamp hinge is a three bolt vs the two bolt Boler. So, if the Boler hinge is in good shape, the guts for pivoting are replaceable: Door Hinge Repair Kit (Brass Ball, Spring, Nut & Bolt). I've read on Bolerama that it's suggested to replace the bolt with one made of stainless steel.
Now I gotta go look at your pics!
boler
boler door hinges Brandon G Problem Solving | Owners Helping Owners 3 07-23-2009 10:01 AM
Door Hinges Phillip Modifications, Alterations and Updates 8 06-23-2009 02:34 PM
Looking for some Door Hinges.... mcnick Problem Solving | Owners Helping Owners 23 06-18-2007 06:52 PM
Boler Door Hinges Barbara Gardin Problem Solving | Owners Helping Owners 6 04-10-2006 07:50 AM
Looking for some Door Hinges.... mcnick General Chat 0 01-01-1970 12:00 AM
