Old 09-22-2008, 08:00 AM   #15
Its amazing to me how much the frame flexes too.........
Ken J is offline   Reply With Quote
Old 09-22-2008, 10:34 AM   #16
Steve Hilby's Avatar
Trailer: Compact Jr
When Detroit wanted to address frame torsional flexing on automobiles, around 1934 or so, they added diagonal crossmembers in an x-shape. Might be worth thinking about if you were building your own frame.
Steve Hilby is offline   Reply With Quote
Old 09-22-2008, 12:43 PM   #17
I just installed a new axles - here are some pictures.
Just did a 1300 mile trip and all went well.
Old 09-22-2008, 12:44 PM   #18
Picture #2
Old 09-22-2008, 12:46 PM   #19
Picture #3
Old 09-28-2008, 08:41 AM   #20
Trailer:
(Late reply - just recovered from disc crash.)
The reason that X diagonal cross-members were added to simple two-rail frames was to add some torsional stiffness. However there's a big difference between cars and trailers - cars sit on four wheels and so are able to put big torsional loads into their frames, while trailers sit on only three (two wheels plus hitch) and so torsional loads on trailers are much, much lower.
Well, they're much, much lower unless people start to go mad with levelling jacks....
Andrew
Old 09-29-2008, 02:11 PM   #21
Trailer: Compact Jr
Andrew
Right; absolutely right. Hadn't gotten that far in my thinking.
Old 12-09-2008, 06:56 AM   #22
rudock1's Avatar
Trailer: Perris Pacer 13 ft 1985 / 2002 Mazda B3000 Dual Sport
Hi Folks,
Just a follow up to show off my new axle. I live in California, on the Central Coast. I found South Valley Trailers in Hollister, CA to do the job. The service mgr there, Mike, was very conscientious and did a good job. I ordered a unique configuration and he made sure the factory totally understood the setup.
My 13' Perris Pacer now has a Dexter TorFlex #9, 10* down angle, high profile (for extra lift), reverse orientation on the bracket (flat side out), side mount hanger kit, EZ Lube hubs, installed in a leading arm orientation. Pretty much the same configuration as Ken's above and looks identical.
On the electric brakes a change worth noting. During my research about trailing vs leading arms, I found out from the Dexter apps engineer that I could request 10" electric brakes (they build the axle with TorFlex #10 spindles etc). So... I went for it and so far so good! 10" might be overkill but I figured I could dial back the controller. Also, we needed to swap the left and right side brakes around because of the leading arm placement.
Overall, we're about 4" higher than before.
Here's a look-see:
thx
Billy
rudock1 is offline   Reply With Quote
Old 12-09-2008, 09:03 AM   #23
Very cool! Do you have pictures looking from underneath?
For some reason, and I see its the same as yours, the wheel in not centered in the wheel well - its a little forward, on mine they are different on each side - mine rally tracked well.
Ken J.
Old 12-09-2008, 10:11 PM   #24
Roy in TO's Avatar
I wish I knew that you could order a Dexter #9 with 10" brakes 6 months ago!
That will make a huge difference on brake fade and wear.
Thank you for letting us know that's possible.
Old 02-06-2013, 07:57 PM   #25
Trailer: 1974 perris valley 13 ft trailer
My thanks to all of you for the frame comments, I have just cut all the body to frame bolts on my 74 pacer that I just have gotten in past few months stripped it down and maybe tomorrow will take body off, my frame has a bow in it aft of the axle of about three inches, looks like a new frame is going to get welded up, My frame rails appear to be made of 2 in square tubing, good thing this is a project, my early completion est. just went out the window this forum has been a good tool, thanks when I get my grandaughter to help I will load some pic. of my beast.
mechanic is offline   Reply With Quote
axle, perris pacer
Vin on frame for a Perris Pacer Darren S W Problem Solving -- Owners Helping Owners 2 03-03-2010 04:21 PM
Perris Pacer first tow Darren W General Chat 13 10-05-2009 03:47 PM
Axle and frame work Carol A. General Chat 10 05-20-2007 10:06 PM
Perris Pacer Rosanna Opperman General Chat 7 04-29-2007 09:56 AM
Perris Pacer General Chat 0 12-31-1969 06:00 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
