13' Scamp Floor Pattern - Fiberglass RV
Old 06-25-2015, 11:40 AM   #1
I picked up an 81 scamp that has no floor. Anyone have a pattern or drawing of the floor. Thx in advance
Ware_curtis is offline   Reply With Quote
Old 06-25-2015, 04:48 PM   #2
Trailer: 2014 Escape 21, Lil Joe
Welcome Curtis
The lower floor is pretty easy. 3 pieces one small piece under the front seat, one large main piece from front to back, then there is a piece from the main floor to the door enterance. There is extra frame support where the pieces join together. All the lower floor joints and edges need to be sealed to the frame with adhesive calking.
The upper floor is four pieces, front goucho area. Lines up with drop floor from side to side. The rear dance floor, lines up with the drop floor across to each wheel well and it fills in to the rear wall. Section 3 is under the kitchen area from the rear drop floor to the front drop floor, you have to cut around the wheel well and this piece overhangs the lower floor. There is a little piece of wood in the bottom of the closet but no overhang on the closet side. The upper floors need to be sealed to the frame around drop floor.
I use 5/8" exterior plywood with the road side sealed with resin. Attach the floor to the frame with wood to metal counter sunk big head screws.
No standard patterns, you have to make your own templates. I use lauan and tabs of cardboard to make my patterns.
I found it is best to replace the upper floor one section at a time. Also make sure your door frame is lined up before glassing the floor to the door frame.
Good luck
Eddie
Old 06-25-2015, 06:48 PM   #3
New Floor
Thx Eddie,
To make the pattern on cardboard do you trace the bottom of trailer?
Old 06-25-2015, 07:27 PM   #4
No, the bottom curves in. The shell needs to be blocked up in place just above the blocked up frame. The frame should be in the frame slots in the shell. There should be about a 1/4 gap between the shell and frame rail. You should be able too see where the floor was tabbed to the shell. The big issue is to keep the door opening properly aligned with the frame ears for the door. Also there should be a gap between the shell and back bumper.
You have your hands full if all the floor is gone. If you you wanted to take the shell off the frame, the upper floor sections should be attached to the shell while the shell is off the frame.
Eddie
Old 06-27-2015, 08:14 AM   #5
Trailer: Casita 16', Sunrader 18'
Send a message via Yahoo to roy vannoy
At Eddie, due you have any pictures of the floor attaching to the wall and frame.
roy vannoy is offline   Reply With Quote
Help... Looking for a pattern for 16 SD Casita Shelf Legacy Posts Problem Solving | Owners Helping Owners 4 05-16-2019 12:26 PM
Scamp cushion pattern AKscamper Problem Solving | Owners Helping Owners 6 05-08-2015 10:16 AM
Scamp wheel bolt pattern Brian Bran Towing, Hitching, Axles and Running Gear 6 05-08-2011 05:39 PM
5'X8' pattern rug! Ryan Kennelly Modifications, Alterations and Updates 10 05-05-2006 10:12 PM
Pattern for a 16' Casita Bed... Legacy Posts Problem Solving | Owners Helping Owners 9 02-25-2003 09:15 AM
