13' Scamp Stinks! - Fiberglass RV
Old 07-22-2007, 02:04 PM   #1
Trailer: 13 ft Scamp
This little fella stinks to high heaven, moldy and musty.
We have shampoo'd the carpet and upholstery, used fbereeze and Drizair and it still just, well,
stinks!
Any words of advice?
Many thanks
Kate Carney is offline   Reply With Quote
Old 07-22-2007, 02:08 PM   #2
Lainey's Avatar
Trailer: 1989 Bigfoot 17 ft and 1989 Li'l Bigfoot 13 ft
Have you taken the covers off the cushions and washed the foam, maybe the shampooing didn't get through it completely?
Are there any concealed areas that had water leaks, maybe rotting plywood or something?
Lainey is offline   Reply With Quote
Old 07-22-2007, 03:42 PM   #3
Sounds like I need to take the covers off and check!
Just last weekend we dicovered a ton of nasty old fiberglass insulation stuffed around the friege, we removed, but no noticeable difference yet
Thanks!
Old 07-22-2007, 11:35 PM   #4
Trailer: 1977 Scamp 13 ft
We just bought a '77 Scamp 13' that wasn't moldy, but smelled generally kind of "lived in"... I agree with the suggestion to take off the cushion covers and check... one of our cushions in particular was really smelly and gross. Donna had a good suggestion for washing cushions (set out the cushions on a blue tarp, get out some soap and a hose, and do a grape stomp-rinse routine). While you've got the cushion covers out of the trailers and off of the foam, you can isolate them to evaluate whether they might be an independent source of smell.
Another possible place to check... under the dinette and front sofa. When we removed our dinette benches to replace the carpet, we found lots of general dirt and grime in the corners underneath. Nail brushes and Krud Kutter ended up being our cleaning tools of choice. We took out and cleaned the water tank while we were at it, and replaced the hose. There was a piece of fiberglass insulation stuffed behind the water tank; replaced that too. After all that, we painted the floor and lower part of the interior (below the plywood that supports the dinette benches) with some of that Zinsser anti-mold/mildew/rust primer. Of course, during all this process, we had the trailer opened up several hours at a time, and that probably didn't hurt either....
Rebecca H. is offline   Reply With Quote
Old 07-23-2007, 01:04 AM   #5
Trailer: 1975 Trillium 13 ft / Chevy Astrovan
After doing a thorough scrubbing, and cleaning all the nooks and crannies that I could reach, our Trill still didn't smell fresh, even though it hadn't been used much in its 30 years. Airing the cushions out in the sunshine help some. So did opening windows and frequently airing it out on warm sunny days.
Biggest source of mustiness seemed to be from the storage compartments and back in around furnace and frig. Wrapped a bunch of charcoal in some muslim to make little packets and scattered them about in strategic locations.
Connie M. is offline   Reply With Quote
Old 07-23-2007, 08:40 PM   #6
Thanks for all the advice folks, you know I have not really cleaned the walls. So this evening I cleaned the inside of the front door using simple green.
EEEEUUUYYYYUUUUWWWWWWW!!!!!!!!!!!
Any suggestions for a good cleaner?
Old 07-23-2007, 10:49 PM   #7
Greg A's Avatar
Trailer: 2015 Escape 19
Ours had a smoker for 20+ years. We took the inside down to the ensolite and scrubbed it with fantastic to get the nicotine off and then painted with Zinsser Perma White which is a mildew sealing paint. Like brand new now.... You'd never know it ever had any odors.
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 07-23-2007, 11:22 PM   #8
Trailer: 2007 Trillium Outback / 2007 Toyota Tacoma
A bowl or dish of fresh unused coffee works well. Or wrap some coffee up in cheese cloth and leave it in things like fridges. Old transport trucker friend used to haul a load of fish one way, spread a five pound bag of coffee on the floor and then load up with fresh vegetables for the return trip. Never had a complaint about fishy veggies.
Brian T is offline   Reply With Quote
Old 07-24-2007, 01:55 PM   #9
I do believe we are going to follow your lead. How much paint did you need?
Old 07-24-2007, 02:25 PM   #10
Greg A's Avatar
Kate,
It took around 8 quarts and I found the paint at Lowes.
Zinsser Perma White
Here is a photo showing paint going on ensolite old/new.
We haven't had any issues with it now that the Scamp is in-use and if you need to touch up we always have it available if the kids scuff up something.
Owner:
Old 07-24-2007, 03:49 PM   #11
Lizbeth's Avatar
That's what I did too my trailer was gross and filthy. It was a lot of work but worth it. The paint is holding up really well.
Old 07-24-2007, 05:15 PM   #12
Kate,
Zinsser Perma White
Attachment 9086
Wow!
Well then, looks like a done deal. It's going to be a busy weekend but it will be one I will be happy at the end of!
Wish us luck!
Old 07-24-2007, 05:17 PM   #13
Kate,
Zinsser Perma White
Attachment 9086
Whoops
One more question.....
How long did it take to dry?
Old 07-24-2007, 07:19 PM   #14
Greg A's Avatar
Three to four hours between coats, and then after two coats a good few days to make sure it was cured up.
If you are gonna gut, clean, paint and replace, ur in for a good bit more than a weekend.
Really no other way to do it, though, cause if you leave an area out behind cabinets or something you'll still be potentially in for odor.
Owner:
My front bunk stinks Amy M Problem Solving | Owners Helping Owners 5 12-01-2009 02:27 AM
1978 scamp stinks, what to do? Drew Bogner Problem Solving | Owners Helping Owners 18 03-16-2007 02:53 PM
leaks lead to stinks Drew Bogner Problem Solving | Owners Helping Owners 7 02-24-2007 03:02 PM
