Originally Posted by gerejon
We have the model Scamp with the side dinette. When I go to turn the table into a bed I can't get the white round pipe with the plastic ends to come out of the base. I had to resort to taking the screws out and beating it out with a hammer. I either have to find out how to solve this or get a bigger hammer since we use it as a bed every night. Help... somebody must have solved this problem in the past. Thanks
What you're describing doesn't sound like
Scamp Standard equipment so you might not get specific answers. Maybe a picture or two would help.
As a general rule when something is sticking or a moving part doesn't like to move cleaning and lubricating will fix the problem. I don't think I would use the fix WD40. WD40 has a tendency to leave residue and get sticky. On plastic (usually nylon in these cases) a very
light coat of a teflon based lubricant or a very
light coat of petroleum jelly should do the trick. Clean the mating parts really well before adding any lubricant.
