17 Foot Boler Floor Type? - Fiberglass RV
Old 12-30-2013, 04:05 PM   #1
Trailer: Boler 1700
I have started in on a restoration of my 17 foot boler. I am at the point where I am pulling up the old sheet linoleum. The previous owner had put a floating sheet of linoleum over the original layer. Once this was up I noticed that there are several layers to the floor.
It seems that the lowest layer is plywood with fiberglass on top (doesn't look like there is resin on the bottom). This plywood if glassed into the shell around the edge. The next layer is a fiberglass sheet that covers the entire floor almost as a basin (although it has no raised edges). Finally there is the original linoleum attached to the fiberglass sheet.
I have attached images (1 image looking down, 2 looking up from underneath trailer) which will hopefully explain what I'm seeing.
My question revolves around the fiberglass sheet that is between the linoleum and plywood and what it's purpose is as some sections were already removed by the previous owner.
Thanks for the help.
Kees
KeesV is offline   Reply With Quote
Old 01-09-2014, 12:52 PM   #2
That is an interesting lay up of material. In my Boler 1700 it is reversed. I had an entire shell(fiberglass on the outside and a 3/4 inch plywood floor above that with linoleum glued to that)
I removed the plywood as it was rotten in many places. As plywood is breathable your manufacturer may have installed the fiberglass on top of the plywood as an internal water barrier and this would also allow the plywood to breathe.
Is the fiberglass similar to the shell or is it glass layered on top of itself and epoxied?
Graham B is offline   Reply With Quote
Old 01-09-2014, 07:48 PM   #3
Trailer: Boler 1700
Thats interesting! The fiberglass looks like it may have a gel coat on one side (it is tan colored) but it is not nearly as thick as the shell of the trailer. The fact that there is two layers of fiberglass is confusing but at this point I have pulled up the top layer leaving shell and single layer as one piece (fiberglass on the bottom).
boler
Wanted - Older 13' Scamp, Boler type near OH techdesigner Wanted: Molded Fiberglass Travel Trailers 1 08-04-2012 11:38 AM
Boler Bag Awning - Should I buy 7 foot or 8 foot? Kurt in BC Modifications, Alterations and Updates 12 09-16-2011 08:58 PM
MS | 16 Foot 2010 Scamp floor plan #4 beckyruns Classified Archives 10 03-19-2011 08:36 PM
List 13 foot eggs with a vertical seam (Burro type) Matt, H General Chat 0 10-07-2009 10:06 AM
floor is recessed on a 99 casita SD 17 foot KellyT General Chat 9 05-13-2009 07:43 AM
