17 foot Casita rear wondow leak - Fiberglass RV
Old 08-18-2019, 05:38 PM   #1
Trailer: 17' Casita Spirit Delux
Delaware
My rear window was broken out of my Casita trailer. A new window was installed and it is leaking. Any guidance anyone can give me to get this rear window leak repaired properly will be greatly appreciated!
ccornell is offline   Reply With Quote
Old 08-19-2019, 06:57 AM   #2
John in Michigan's Avatar
Trailer: 1979 Boler 1700
First need to pin down exactly where the water is coming in. Can do this by spraying water on the window with a garden hose while a second person carefully observes from inside. Possibilities are:
- Between the outer window frame and fiberglass body. If this is the case, remove the entire window, re-seal with a thick layer (or double layer) of butyl tape and re-install.
- Through factory seams in the outer frame. Use a marine grade sealant or epoxy to seal seams.
- Between the sliding and/or fixed sash and the outer frame. If water is slowly rising in the bottom track, make sure the weep holes are not plugged up. Also look for gaps in, or missing rubber/plastic seals.
- Around edges of glass pane(s). This requires removing and re-sealing glass pane(s).
Old 08-19-2019, 07:42 AM   #3
Originally Posted by ccornell View Post
My rear window was broken out of my Casita trailer. A new window was installed and it is leaking. ..
Who replaced it? If a business did, then go back and insist that they do it right.
If you replaced it, then describe how you went about it. Any problem with the method can then be identified.
Old 08-19-2019, 09:10 AM   #4
Trailer: Casita 17 ft. Liberty Deluxe
Captain tolley's creeping crack sealer will work well if the leak is not large. It's a clear thin liquid that will run into all the cracks and seal them you can put multiple coats of it after it dries dries.
J Ron is offline   Reply With Quote
Old 08-19-2019, 10:52 AM   #5
Agree with Gordon. Who did the installation? Point of clarification: was the whole window replaced, or just the broken glass?
Even if I were having someone else fix the leak, it never hurts to do a little testing yourself. A container with a pour spout will allow for more precise aiming of water to pin down the leak. Work from the bottom up.
There are three common ways a window can leak (from most to least likely): (1) It can leak around the outer flange where it is sealed to the fiberglass shell, caused by a small gap in the butyl sealant. That would be the first thing to check on a new installation. (2) It can leak at the bottom channels where the window panes slide. If the drain slots (weep holes) are blocked with debris or incompletely punched on a new window (a "hanging chad"), rain fills the channels and overflows into the trailer. (3) it can leak around the internal seals between the glass and the frame. That's more common on an older window, but if a pane was replaced, it might not be completely sealed into the frame.
casita
Mega-Disaster: Leak under rear bed whoot Plumbing | Systems and Fixtures 12 11-25-2015 10:09 AM
Rear Window Leak snorton711 Problem Solving | Owners Helping Owners 10 09-02-2014 08:20 PM
Leak(s) in rear of Trillium Maggie R. Problem Solving | Owners Helping Owners 26 08-11-2011 11:13 AM
Water Leak -Puddle under rear window cushion Dave Storey Problem Solving | Owners Helping Owners 14 05-06-2011 11:56 AM
