18 degrees and no LP in Casita - Page 3 - Fiberglass RV
Old 01-07-2016, 04:58 PM   #29
Connecticut
Hey Bill,
All I have to say is God Bless Ya! I thought at one point you had a line on a job in Mobile Ala. Hopefully El Nino will keep temperatures somewhat moderate. If you were doing this last year, things would most likely be a lot tougher. Here in New England last year we had tons of snow and temperatures that stayed in the 20's for three months. (coldest winter on record here) I wish you the best you're a trooper and come spring you should be a cold weather camping expert. Good luck and hang in there.
wwig is offline   Reply With Quote
Old 01-07-2016, 05:47 PM   #30
CampyTime's Avatar
Trailer: Scamp 13' Standard
Ditto that reply! What a trooper this guy is! God Bless him!
Old 01-07-2016, 07:35 PM   #31
Trailer: Casita SD17
New Jersey
Thanks for the support! If I can make it through the NJ Winter, that will greatly increase the types of places I would be willing to travel too.
The last major points of exposure for me are, a power outage, and the ground freezing. When I had an apartment, Hurricane Sandy hit NJ, and knocked the power out for 2 weeks. If I lost electric power now, I wouldn't be able to heat my propane regulator, and I would quickly lose my gas heat. If the ground freezes, it's not as bad, I just wouldn't be able to get freshwater or dump my tanks. I'd have to go to a hotel after a week or so. Last year, before I was in the Casita, the campground water lines froze for 4 weeks. Hopefully this winter will stay mild!
Maybe I should get one of those Honda generators with the inverter built in, then I wouldn't have to worry so much about a power outage.
whoot is offline   Reply With Quote
Old 01-07-2016, 09:12 PM   #32
Trailer: Casita 17 ft SD
Wisconsin
Originally Posted by Darwin Maring View Post
As Greg Pointed out above, NOT GOOD ADVICE. Putting an electric heat wrap on a propane tank or gas lines would be highly ill-advised. Those heat tapes have been known to over heat, burn through, and create shorts. Not exactly conditions you would want around an extremely flammable fuel container unless you plan to arc weld on the tank or lines...
I used a heat tape that had a thermostat on it and wrapped the outside copper line with it. Did this for 5 Years of winters where I lived full time. The one thing that you must never do is to cross your heat tape with the heat tape. It will get to hot where the tape crosses over its self and melt through. My heat tape was connected to a ground fault isolated receptacle thus giving me some sort of safety factor should a short happen.
Even though I used the tape on the gas line does not mean that you should. If you do, you do so at your own risk.
You can cross self regulating heat tape (Raychem)
Old 01-07-2016, 09:18 PM   #33
Wisconsin
When temps got to 30 below Zero , we were told to get off natural gas and switch to propane. We heated our propane tanks and lines with steam tracing to help the propane vaporize. 20 deg above zero is not cold , cold is 30 to 50 below zero.
Old 01-08-2016, 11:52 AM   #34
Victor Benz's Avatar
Here is one other possibility that has occurred to us, hear in the "far north". Where was your propane tank bought or last filled? Propane is never pure propane. It is a distilled refinery product, and it always carries some lighter (such as ethane) and heavier (such as butane) components. The further south one goes in North America, the more the butane content of the gas sold as propane. If a tank filled in Florida is brought to Alberta, it is very possible that it would freeze the regulator in winter operation due to the much higher butane content. Butane boiling point is about 0˚C or 32˚F depending on the specific butane isomer.
I have personally experienced this with a tank filled in California and used in the fall here in Alberta.
Victor Benz is offline   Reply With Quote
Old 01-08-2016, 12:57 PM   #35
I lived in a travel trailer for a couple of winters. Sounds like you have skirting around it if you are putting heaters on it. I had the water hose heat taped and I had the gray tank opened and left a trickle of water running. I was lucky and the coldest it got was 3 instead of a normal, colder spell. You might try letting your water trickle or drip to keep it thawed.
It was a 1970something Kit Companion that I was in. I was so glad when I found a house to rent.
slowpat is offline   Reply With Quote
Old 01-08-2016, 09:22 PM   #36
Mike Magee's Avatar
Trailer: Li'l Hauley
It should be possible to reduce the rate of interior heat loss (and improve comfort) by adding some insulative material onto the roof. A few square bales of straw, for instance. (Provided the campground folks don't think it looks too ghetto... ) Necessity is the mother of invention, and experimenting might yield favorable results.
How to prepare Tofu
Step 2: grill some meat
Old 01-09-2016, 08:29 AM   #37
Hay Mike, I read your post and heard Banjo music.
Old 01-12-2016, 07:27 AM   #38
Do you have 12 Volt DC?
Old 01-14-2016, 03:36 AM   #39
Trailer: CASITA
LOL
NEWYORKHILLBILLY is offline   Reply With Quote
Old 01-21-2016, 04:44 PM   #40
New Jersey
Update: Every thing is going well. When the temperature is over 25 degrees, the skirting keeps the bottom of the Casita above freezing, so I don't have to worry about the plumbing. Above 25, I run a 1500 watt space heater inside the Casita, and use propane in the water-heater (it acts as a little furnace under the Casita). I use a Holmes 1500 watt heater ($45 on AMZ), which seems way more solid than the $20 heaters at Walmart).
Below 25, I turn on the 1500 watt space heater under the Casita, aimed at the valve. I also started putting RV Anti-Freeze in to the Grey/Black tanks immediately after dumping, so the Anti-Freeze goes to the valve.
The propane tank gauge seems frozen, and just says the tanks are full, so I just have to let it run out without warning. The gauge no longer cuts off the propane since I put the heat-tape on it. The whole regulator is wrapped in heat-tape and Reflective. I got heat-tape that only heats enough to keep it at 45 degrees.
When it gets below 20, I use the inside propane furnace instead of the space-heater. With the furnace and hot-water heater on, it was 80 inside when it was 10 outside.
I have 5 space heaters, though I only use at most, two at a time. The Holmes is way better than all the others. It has a wide base, so there is no chance of a tip over. The other 4 are $20-$30 ceramic heaters. I put a toilet-seat under the Casita for the space-heater to sit on. It keeps it high enough, and water/condensation easily rolls off. The skirting hides the toilet seat.
We are expecting a lot of snow in the NE this weekend, but I'm not worried. Everything is okay when it's over 25 degrees. As long as I have city water coming in, sewer lines working (not frozen), and lots of electricity, I'm fine. If I wasn't able to use the electric power from two lots, I would run one space-heater underneath, and use the heat-tape to keep the propane gauge working. Then I would use the propane furnace to keep the inside warm.
One weird thing I noticed, using propane in the hot-water heater seems to increase the water-pressure, so it "shoots out" when you first turn on the hot-water. I suspect that increased pressure caused some of my water leakage last month. Now, I turn on the hot-water to release the extra pressure every 6 hours or so. The electric water heat did not do that.
Old 01-22-2016, 01:42 PM   #41
TheWanderers's Avatar
Trailer: 1988 Bigfoot Fiver
Kentucky
Glad you have a system figured out! Wow! Way to go. Stay safe AND warm!
"Not all those who wander are lost." J.R.R. Tolkien
TheWanderers is offline   Reply With Quote
Old 01-22-2016, 01:50 PM   #42
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
Sure hope it works well in this storm. Please keep us updated.
Walt
casita
A year-long road trip @ 70 degrees F. Sands General Chat 4 10-27-2015 10:58 PM
Allure flooring. Install <65 degrees F? Tonia Modifications, Alterations and Updates 31 07-19-2013 12:12 AM
70 Degrees F (21 C) Arghhhh! General Chat 0 12-31-1969 07:00 PM
32 degrees -- Life is good! General Chat 0 12-31-1969 07:00 PM
